e90 booster with S54
  • Staszek
    • 2533
    I saw a lot of posts floating around about this, but I havent seen a final if this has been completed and if it works. Seems like a really good solution.
  • BMW_TUNER
    • Jul 2006
    • 1386
    Isn’t the MC very different in attachment and layout?
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
    • Staszek
      • 2533
      It is, although the E83 X3 fits in it and is reversed so it will work. I bought both and I am going to try it, its more plug and play than the other ones and definitely has better-stopping power. We will see!
        • 34844
        well as you know, it's been done with an N52 - although with an N54 manifold, which is quite a bit smaller than the S54 airbox or N52 3-stage.
        The good thing though is they are newer (unlike a 40 year old Porsche or 2002 booster) and they are dirt cheap.
        • E30SPDFRK
          • 5716
          Byron
          Leichtbau
          • Staszek
            • 2533
            Bought one, let you guys know how it works when I finally get around to installing the engine. It's definitely a lot smaller than the E30 booster, but bigger than the 2002. Its shorter than the IX. I am thinking I still may have to do some adjusting to the manifold, but not nearly as much as I would with an E30 booster.
            • rjmcdermott81
              • Oct 2014
              • 568
              Interested to hear how this works. My 2002 booster had zero clearance with the s54. I really had to jam the intake down to get it all to fit. I couldn't imagine fitting anything bigger in there.
              Build Thread: Ryan's Hennarot 318is
              COTM Aug 2019
              • kid8
                • Jul 2013
                • 312
                Is it any narrower than the IX booster?
