Mss54 s54 swap speed signal
  • BMWfanz
    • Dec 2013
    • 46
    Hi guys! Currently having a problem that ECU doesn't see signal , I've changed speed signal bit in my map and changed digital signal to analog one. So now I need to wire signal from dashboard/diff to same pin for speed signal or I need special decoder because s54 z3m sees this signal from ABS module?
    • 34839
    just use the output from the back of the cluster. That's what those code changes are for. in fact the stock E30 DME gets a VSS signal, it's right in the C101.
    • BMWfanz
      • Dec 2013
      • 46
      Is there any calibration maps available in ECU? I've connected signal from instrument cluster and there is a signal i can see in INPA diagnostic but wrong values- for example 40 km/h- 3 km/h in ECU- 65 km/h- 5 in ECU
      • BMWfanz
        • Dec 2013
        • 46
          • 34839
          yeah, I'll have to look it up - there's a 'k factor' value you can scale to get the right speed.
          • BMWfanz
            • Dec 2013
            • 46
            Nando can u help me with it? Or its needed to be online when calibrated? Im from almaty and I have fully downloaded ecu flash
            • R3Z3N
              • Jan 2011
              • 3056
              Calculation: Pulses/KM
              E30 9 Pulses/Rotation
              So: Tire Rotations/KM*9
