M54. Let the foolishness begin.
  • hoveringuy
    • Dec 2005
    • 2682
    #301
    The bolt pattern is different between the M50 and M54, but I'm sure that would be easy to adjust. Michael hasn't said anything about producing these in quantity, I'm showing what can be done and with interest anything is possible.
    • gregslow318i
      • Sep 2007
      • 1918
      #302
      Steve cut the crap start on the s54 already.....:hitler:
      looking for a e30m50 swap harness adapter pm me $150 shipped
      email nitroman12@gmail.com
      • Wh33lhop
        • 11705
        #303
        And start selling kits! :p
        paint sucks
        • dude8383
          • Jan 2005
          • 10387
          #304
          I second...err third the notion!
          • Spaz
            Crazy Canuck
            • 2276
            #305
            here here.
            Cam .W '91 325is
            Spaz's 1991 Alpine White???? S52 Build Thread...
            • hoveringuy
              • Dec 2005
              • 2682
              #306
              Frank Ramos alerted me to the fact that the M44 crank sensor is a replacement for the M54 sensor, except that it is VR instead of Hall.
              This means a Hall conversion circuit is no longer necessary, I can get a native VR signal!
              The sensor is plug compatible with an M50 harness and fits the block perfectly. I'm guessing this is also the case with the M52 and S52.
              I've replaced my Hall sensor with the M44 VR one and the car runs. Only issue I am having so far is that the VR sensor generates very good voltage, but only tiny amounts of current. That little bit of current needs to satisfy both the 413 ECU and my VANOS ECU.
              The part number on the sensor is 12141247622
              • matt
                • 3731
                #307
                Nice, thats a great piece of info to have. Thanks.
                • Mde36
                  • 509
                  #308
                  Just read this entire thread an it is spectacular. I laughed, I cried, I had to change my underwear. The level of dedication ingenuity and fabrication is amazing I've been inspired to do something on my car.
                  Powered By Ford
                  • Spaz
                    Crazy Canuck
                    • 2276
                    #309
                    Hmm interesting information about the crank sensor!
                    Thanks for sharing.
                    -Cam
                    Cam .W '91 325is
                    • hoveringuy
                      • Dec 2005
                      • 2682
                      #310
                      Thanks for sharing.
                      -Cam
                      I thought it was important because it's a plug-n-play option for M52/S52 OBD1 conversions.
                      • himizoli
                        • Jan 2009
                        • 8
                        #311
                        Finally our M54b30 in E21 started up. :p
                        • jrdeamicis
                          • Nov 2008
                          • 956
                          #312
                          I still love this thread. My OBD2 S50 will be firing up this week. More to come.
                          Past Car : E30 S50 6 Speed 5 Lug 3.73
                          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                          ___________________________________________
                          BNB Designs
                          Engine Swaps, Fabrication, Innovation, General Repair
                          Richmond CA
                          Julian 848-248-8029
                          • kariotahi
                            • Sep 2007
                            • 8
                            #313
                            Steve, thanks for all your help. This is just to let you know it's all up and running now.
                            I've fitted a M54B30 into an E30 dedicated race and track car. Not out of the ordinary, except that the twin vanos has been removed and the cams locked, it's running all M50 bits other than the head and block, including the M50 front crank wheel and M50 crank sensor. I've used the Zionville front thermo housing adaptor and blocked the heater hose outlet on the head. Have used the M50 intake and fitted and locktited set screws into the extra air inlet holes the m54 has at the intake. I'm using the 402 DME and am getting it remapped next week on a dyno, will let you know the results, but am hoping for around 220rwhp.
                            Again, Thanks.
                            • castros
                              • 828
                              #314
                              WOW you are crazy. sick stuff :up:
                              www.CASTROMOTORSPORT.com
                              Castro Motorsport
                              12600 Sherman Way, Unit C
                              North Hollywood, CA 91605
                              818-765-3606
                              Follow Castro's on Facebook:
                              http://www.facebook.com/pages/Castro...02411516506828
                              Follow Castro's on Instagram:
                              http://instagram.com/castromotorsport#
                              • kariotahi
                                • Sep 2007
                                • 8
                                #315
                                Did the dyno today, came out with 218 rwhp and 250 ft lb of torque, very happy.
