M54. Let the foolishness begin.
  • hoveringuy
    • Dec 2005
    • 2744
    I have the motor. It's nice and shiny all over! It needs some attention before I can even begin to think about getting it running or installing it.
    I'm stubborn so I'm sure I'll make something interesting out of it.
  • Jean
    • 18228
    Awesome! I want it, gimme? lol
    • SpecM
      • Oct 2005
      • 4531
      -Wow, nice. b25 or b30? Are you keeping it OBD 2 or converting? Tell us!!!!
      1989 cirrisblau-metallic 325i
      • hoveringuy
        • Dec 2005
        • 2744
        Oh... details, details... It's a b30 out of a 330 w/automatic. I don't see anyway I can keep it OBDII at this point. I don't quite have the "skilz" to defeat EWS.
        My first task is to pull the head and get it physically up to task, that may not even happen and I'll be left with a junk head and some nice internals, although I think it will be Ok.
        My inclination on this motor is to go standalone injection and then develop a dual-VANOS controller. I haven't gotten that far yet. I'm still looking at the shiny block...
        • SpecM
          • Oct 2005
          • 4531
          -I am soooo jealous like a lotta bit!
          -But I may have an m54b30 in the lines too. Warped head and pulled block threads; but the crank = stroker time
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            Dual VANOS
            Alum block
            3.0
            FTW
            Good luck, I am very interested in this build!
            • e30s52
              • Oct 2007
              • 5235
              same if this works out then im getting rid of my s52 and going s54 ;)
              www.gutenparts.com
              • hoveringuy
                • Dec 2005
                • 2744
                It's interesting what you find when you start looking...
                http://www.turnermotorsport.com/html..._ID=TEN9990850
                • george graves
                  • 20003
                  Mid-engined e30?
                  Originally posted by Matt-B
                  • e30s52
                    • Oct 2007
                    • 5235
                    wow. thats a good price too for the bracket
                    www.gutenparts.com
                    • gregslow318i
                      • Sep 2007
                      • 1918
                      oh no a local swap I am subscribed!
                      looking for a e30m50 swap harness adapter pm me $150 shipped
                      email nitroman12@gmail.com
                      • Drew325is
                        • Oct 2004
                        • 520
                        Oh hell yes!!!!! This will be awesome :D
                        • hoveringuy
                          • Dec 2005
                          • 2744
                          The motor came apart like butter and I've had a good look at the head. I was hoping for the "Eureka!" moment when I could see what was causing it to blow white smoke but couldn't find that. No visible cracks in the exhaust valve seat area like I feared.
                          So, it's off to the machine shop for pressure testing. At this point it was either just a squooshed head gasket or a there's a crack somewhere else in the water jacket.
                          It also looks straight with the best straight edge I have.
                          Could I be lucky enough that it's just the head gasket??
                          • pedal2metal
                            • Jun 2007
                            • 93
                            Check for a crack in the area between #5 and #6 spark plug bores in the top of the head. I've seen about a dozen of them. Usually the tell tail sign is the milkshake lookin coolant. And I'd recommend replacing the camshaft ledges (trays) and all lifters...depending on mileage and visible scoring on either surfaces.
                            • Ray Smoodiver
                              • Jun 2004
                              • 8809
                              Badass! The only M54b30 swap I've seen hauled ass. Good luck mate!
