N52 swap E30 build
  • Rich82
    • Jul 2015
    • 4
    N52 swap E30 build
    Hi Everyone, been thinking about N52 swapping my E30 for a while now. Finally got a donor X3. So what do I need to keep from the X3 before I part it out?
  • hoveringuy
    • Dec 2005
    • 2744
    Not much besides the engine. You'll want to grab the EKP module because I think X3 is the correct CAN protocol. Otherwise engine and some spare wire.
    EDIT: sorry, meant the EKP...
    • Striker01
      • Jul 2011
      • 378
      Grab the IVM and all it's connectors, I think some of the X3s had them. Make sure you get the X60001 connector, it's the gray 26 pin in the small ECU connector, should run to the bodyside wiring. Also electric pedal with connector/pigtail.
      When you pull the EKP I'd try to pull as much of the twisted pair for the CAN signal as you can, I used probably 10'ish to run from glove box area to the backseat cavity. hoveringuy​ posted the pins you'll need to order in the N52 swap discussion thread, they're cheap so you might as well re-terminate what you can to avoid splices.
      • Rich82
        • Jul 2015
        • 4
        Thanks guys, need to do a fair bit of reading up as I don't know what an EKP module or IVM is.
        • Striker01
          • Jul 2011
          • 378
          Start here. Long thread but covers almost everything you need to know: https://www.r3vlimited.com/board/for...wap-discussion
          Also look at the threads for individual things like engine mounts and oil pan.
