N52 swap wiring pins/sockets for ECU and IVM
  • Striker01
    • Jul 2011
    • 378
    After my mess up with re-pinning some of the ECU connectors I thought we could use a post dedicated to wiring. Most of this info was posted by hoveringuy in the original N52 swap discussion but one set of pins he couldn't find on digikey so I did some searching and found some that fit.
    You will need 3 types of sockets if you are planning on using MSV70/80 and the Z4 IVM. The only pin I don't have listed is the main power to the IVM. I just used the existing one, it will reach the battery terminal without re-terminating.
    Digikey PN 17-5-928999-1CT-ND. Small pins on IVM, marked yellow in the pics.
    Digikey PN 17-929396-1CT-ND. Small ECU pins, marked orange in the pics.
    Digikey PN A122193CT-ND. Large pins on ECU and IVM, marked red in the pics.
    Click image for larger version  Name:	IMG_1482.jpg Views:	125 Size:	265.5 KB ID:	10132828
    Click image for larger version  Name:	IMG_1483.jpg Views:	126 Size:	288.6 KB ID:	10132827
    Click image for larger version  Name:	IMG_1481.jpg Views:	133 Size:	297.1 KB ID:	10132830
    IVM. I borrowed this pic from hubcapboy​. The case is removed but I couldn't find another pic.
    Click image for larger version  Name:	IVM.jpg Views:	151 Size:	41.4 KB ID:	10132826
    ECU
    Click image for larger version  Name:	IMG_1477.jpg Views:	128 Size:	233.3 KB ID:	10132829
