S38 on Megasquirt
  • E30mpd
    • Feb 2019
    • 55
    Bumping old thread .. anyone successfully get megasquirt running on their s38b35 35pin ?
    • downforce22
      • Aug 2009
      • 3193
      i dont think you will be able to run it motronic 1.0 35 pin 079 ecu because you need the 60-2 trigger wheel and crank sensor. M1.0 uses 2 sensors in the bellhousing instead of 1 on the front the crank. You would need the s38b36 350 ecu and associated parts or retrofit a 60-2 toothed wheel and crank sensor from m30b35/s38b36
      • e30m3s54turbo
        • Jun 2010
        • 3292
        Bumping old thread.
        Im using MSII on my s38 turbo e30.
        • Haruki Wiring Solutions
          • Oct 2024
          • 2
          We are installing a FuelTech FT550 into a M5 E34 S38B38.
          It's very hard to find any info about this engine electronics over the internet (the best I could find is a wiring diagram in german). What I could also find out is that the 1995 S38B36 uses an ECU with the same 88 pin connector and most of it's pins are in the same arrangement as the B38 ECU.
          When we finish this project I will share some videos / pictures over here.
          • e30m3s54turbo
            • Jun 2010
            • 3292
            My s38 b36 turbo is running on Mega squirt II. I’m planning to buy
            Mega squirt III. I had some one wire up s38 to match my e30. I think I still have the sheet he sent me.
              • Oct 2024
              • 2
              If you have something that you could share about it, I think it would be helpful for the community. It's a little bit hard to find good info about these engines.
              It's even harder to find anything about the B38. I think it only came in the e34 M5 in germany (we have a couple of them in Brazil). All the wiring diagrams I could find are in german and it took me a lot of time to translate it.
              • e30m3s54turbo
                • Jun 2010
                • 3292
                What are you searching?
