iX front 5 lug swap info
  • Eskie
    • Dec 2014
    • 162
    Wondering if anyone has info on what components to use for a 5 lug swap on the front of an ix. I know the rear is pretty much the same as a RWD.
    I’ve been scouring the internet for info but anything I’ve found is kind of vague. I even tried using the waybackmachine.com to try to find posts on e30tech.com. I can see some of the posts but can’t access them because they aren’t archived.
    The posts I have found on r3v mention using e87 rear hubs on the front as they are the same diameter of the stock wheel bearings on the ix. Trying to figure out what brake setup is the best. I’m assuming a custom caliper adapter is going to have to be machined.
    Anyone?
    here’s the posts I have found:
  • mtech325
    • May 2008
    • 569
    Older thread, but post #3 has some good info. Could be worth reaching out to IXguido about the caliper adapter brackets:
    • Eskie
      • Dec 2014
      • 162
      Oops I meant to post that thread but it looks like I just posted the same one twice. Not a bad idea. I’ll share any info I find along the way.
      • MFresh2089
        • Oct 2020
        • 6
        Hey, did you ever end up completing the swap? If so, can you share more details?? I want to do this on my wagon.
        • Eskie
          • Dec 2014
          • 162
          No, I didn’t but I’d still like to know. It got put on the back burner for now.
