OEM iX Front Springs?
  • TheSnowBimmer
    • Sep 2023
    • 10
    I'm redoing my suspension and I'm trying to find OEM springs to get the oem ride height how ever I only can find the rear springs and it seems that the OEM front springs have been discontinued. Does anyone of a spring manufacture that makes springs that will keep the OEM ride height and will require no modification?
  • packratbimmer
    • Dec 2009
    • 1331
    There was more than one part number for iX springs up front over the years of production.
    • TheSnowBimmer
      • Sep 2023
      • 10
      Yeah I understand that, however the one I need 31331127503 has been discontinued, unless 31331131943 will keep the same ride height? I'm just thinking it won't considering it fits other e30s as well so I'm assuming its a lower ride height
      • D.Martijn
        • Sep 2016
        • 1022
        Are you sure about those part numbers? When I put 31331127503 into realoem, those show up for "Swedish model with or without airconditioning"
        31331131943 is for convertible models.
        I think you should have a look at: 31331129880 or 31331125341
        1990 325iX Touring - November 2018 R3V Car Of The Month
        1980 Volkswagen Golf mk1 1.1
        1974 BMW 2002 Touring
        Instagram
        • TheSnowBimmer
          • Sep 2023
          • 10
          Looking back to realoem my part number is 31331125341 I was accordingly looking at the superseed I believe,
          Either way though it looks like 31331125341 has still been discontinued along with the other part number you have sent
          • D.Martijn
            • Sep 2016
            • 1022
            When I have a look at some of the European suppliers they list it as available.
            (I live in the EU) Maybe your local dealership can get them for you?
            Instagram
            • packratbimmer
              • Dec 2009
              • 1331
              There is a good write-up in the Bentley manual about springs and includes a chart/s. I remember something about the numbers on the springs not being actual part numbers ( one has to add a one or two depending on the stripe color ) - read page 20 in the steering and suspension section "The identifying numbers..." According to the chart, the 341 spring will only lower the car 4MM when replacing 503
              • TheSnowBimmer
                • Sep 2023
                • 10
                So from what you're saying If I used 503 there wouldn't be a drop or a noticeable one at least? Because I think I found a place that has one.
                But now I'm wondering if the rear springs I found would work, real oem says I need 33539061592 but I was wondering if I could use 33539058926, I'm unsure as my cars prod month was 09/88 but33539058926 says from 09/89 on pelican do you think they would be interchangeable?
                As for the ones realoem says I need, the 33539058926 I'm only able to find here or on websites like this https://www.thebmwminipartstore.com/...30-33539061592 and I'm not sure if websites like that are trusted
                • packratbimmer
                  • Dec 2009
                  • 1331
                  Be aware that ride height with 503 (as seen on the spring itself) will be pretty high. A stock iX will often squat in the back when hauling stuff in the trunk. I actually ran taller springs in the back from a 325e and even tried E36 sedan springs once. Unfortunately, your question does not have an easy answer and might involve some labor intensive experimentation. Though I cannot say that the spring rate was correct for an iX, stock rwd 325i springs in the front resulted in the best stock spring setup on my iX cars. I was not driving in harsh conditions so they worked great. BTW: What size tires do you plan to run? Do you need height for tire clearance? Just looking to get back to factory stock stance?
                  • TheSnowBimmer
                    • Sep 2023
                    • 10
                    I don’t need the ride height as I’m planning on running 205/55 I just prefer the look of the oem height and I’m trying to fully refresh the suspension to get it to oem or oem+ as I’m trying to make it a nice daily
                    • 82eye
                      • Jan 2009
                      • 1938
                      what's wrong with the current springs ? you can probably just get away with replacing the inserts / shocks.
                      • TheSnowBimmer
                        • Sep 2023
                        • 10
                        Don’t springs sag over time? It might be fine but I feel like it’s sagged after a while as it doesn’t look as high as it looks in photos
                        • 82eye
                          • Jan 2009
                          • 1938
                          yeah they do a bit but it's generally negligible. it'd be a bitch if you went to the trouble and wound up essentially at the same place. i've yet to meet a mechanic that advises swapping springs out as a wear item.
                          edit : most times they'll recommend a shock / insert change and call it a day at most. also i think h&r may have a listing for an oe replacement, but not bmw branded if you go with a swap. they supplied the oe springs.
