offset question
  • ploobIX88
    • 31
    offset question
    i really like these rims... but im not sure if they would work with my car. i know the offset for the IX is different then other e30's so i thought i would post them up and see if anyone could let me know if they would work.
    thanks,
    Brandon
    • 34844
    well, he doesn't say what the offset is, but a negative offset 8" wide wheel doesn't have a chance. an 8" wheel needs between ET30-ET36 to fit an ix. a 7" wheel needs between ~25-40.
    • ploobIX88
      • 31
      alright thanks man, i had a feeling they wouldn't work.
      • supernaughtIX
        • Apr 2007
        • 260
        those just have an insane lip on them. Find a place to get smaller lips and you're fine. With a smaller lip, you add +12.7mm of offset per inch of reduction. Plus that wheel looks bigger than 8" wide, with a 5 inch lip, that sure doesnt look like 3 inches to the ground.
        Either way, those don't look right
        88 325 IX DiamantSchwarz - TOURING - waiting...
        89 325 IX AlpinWeiß - Gone
        88 325 IX DiamantSchwarz - Parted
        89 325 IX RoyalBlau - Parted
        88 325 IX RoyalBlau - Gone
        • pawi30
          • May 2007
          • 1091
          emailed the guy this is what he said:
          Hi,
          The exact offset is unknown, although I measured from the MOUNTING surface on the rear of the wheel-from that point to the OUT LIP of the wheel (very edge of the outer lip) is 6" Therefore, it is a negative offset. If you measure on YOUR vehicle from the mounting hub outward-these wheels will extend "poke" out appx. 6 (six) inches from your hub. I hope that gives an idea of the 'offset'
          The wheels are USA made SPECTRUM Custom Wheels manufactured in 1996.
          Thanks for your interest,
          Maxwell
          Originally Said by Bob Marley
          "BMW make pure trouble!"
            • 34844
            that makes the offset about -50mm. not a chance in hell, sorry!
