Finally picked up a 1989 4 door 5spd ix a week ago, but am just getting around to flushing all of the fluids, new plugs, filters, etc...
I've read many a thread on what the common issues are with these cars, so I decided to get the car up in the air and start checking things out. Here are my findings/questions:
1. The exhaust system: What does the piping look like from the headers back to the cat? It appears that the previous owner had someone weld two pipes coming off of the headers into a Y pipe, and then a single pipe goes to the cat. From the cat, dual pipes go to the muffler, they are welded on as well, so I can't replace the rusted only catback as easily as I'd like.
2. The Front drive shaft: With both front tires off of the ground, I can turn the drive shaft by hand, and only one the left tire moves. There is slight movement from the right, but no where near as much as the left. If I spin the left tire itself, the right tire spins at the same rate. Is this anything to worry about?
Also, I can actually see the splines where the drive shaft meets the t-case. Is that normal? I unbolted the drive shaft and found that I could slide it into the t-case another .5 inch or so. I plan on doing the washer modification to get more of the splines in play.
3. T-case: I emptied the fluid to see how much was actually in there, and wow, there was probably only 5-6oz of fluid in the case! The fluid was black and the magnetic drain plug had a huge glob of fine metal shavings on it. I cleaned off the plug and put it back, I plan on refilling the t-case tonight.
4. The oil filter: How the F do you get that thing out? I was trying to twist it off from under the car, but she wouldn't budge. F'n Fram filter.
So, as you can tell, the previous owner hasn't taken very good care of her, but I'm hoping to revive her as best I can. If anyone could point out what is 'normal' and what isn't, that would be a huge help. From what I've read, I kinda figure that the T-case is fried, but we'll see once I get everything back together and fill her with fresh fluids.
TIA
TIA
