ABS Problem :-(
  • BDonati
    • Sep 2009
    • 7
    ABS Problem :-(
    My abs light is on, and i am trying to find out why.
    I have masured the sensors at the wheels and they seem fine. (between 980 and 1000ohm)
    Are there any way to test the abs control box and the Accelerator sensor
    Or is it just a case of replaceing it and seeing what happens?
    Brian Donati
  • iX-treame
    • 440
    Yea the ABS light just means it's turned off due to a problem or it's not hooked up. Check relays and stuff. Sometimes the sensors themself go bad and will start kicking your foot off the brake at low speeds.
    '88 325iX -Totaled
    '97 M3 - Sold
    '85 euro e30 Pete McHenry 2.8L m20 Stroker - Parting out
    '89 325is - Sold
    '95 540i 6spd
    '87 325is M Technic I s50
    • whiltebeitel
      • Apr 2007
      • 2098
      I'd start with the relay under the kickpanel. Pull the aluminum cover off, and you'll see if the fusible link is still good or not.
      '89 325i track sloot
      '01 530i daily
      -Enginerd
      • StereoInstaller1
        GAS
        • 22679
        What car is this in?
        Closing SOON!
        Thanks for 10 years of fun!
        • BDonati
          • Sep 2009
          • 7
          Hi
          Thank you for the advice.
          I will check
          It is an 88 325ix touring
          Is it too unlikely that it could be either the control box or the acceleration thing?
          I think the ix is the only to have this odd acceleration thing?
          • StereoInstaller1
            GAS
            • 22679
            Likely the "ABS Overvoltage Relay"
            Closing SOON!
              • 34844
              is it on right when you turn on the car, or after you drive for a few minutes?
              and yes the ix is the only one with the acceleration sensor. it also has a different ABS computer, and 4 wheel sensors instead of 3.
              • BDonati
                • Sep 2009
                • 7
                It is on as soon as the ignition is on and stays on.
                I will check the posible problems tomorrow and report
