Steering wheel clunk on my '90 iX? Is there an adjustment screw...
  • supernaughtIX
    • Apr 2007
    • 260
    I was able to take a look at the joint with the car on the ground, someone else turning the wheel side to side slightly. You can see it a bit looking down from above with a flashlight, but you can get a better look from behind the driver's side wheel if the steering is turned mostly to the pass side. You have to get on the ground, but its quick to check. At least I think that's how I looked at it.
    You should be able to see or feel some slight backlash between the input and output of the joint - if that's the problem. Sometimes you have to move it around a bit to find the loose spot though.
    88 325 IX DiamantSchwarz - TOURING - waiting...
    89 325 IX AlpinWeiß - Gone
    88 325 IX DiamantSchwarz - Parted
    89 325 IX RoyalBlau - Parted
    88 325 IX RoyalBlau - Gone
    • audiquattrot
      • May 2008
      • 3836
      just an update....replaced the u-joint steering knuckle, and the problem is now fixed! I had a really loose steering + rattling/knocking coming from the steering column which progressively got worse over the last 2yrs. Recently going over bumps was hairy, and the steering was all over the place. The old knuckle out of the car had tons of play. Glad she's fixed now. The steering is nice and tight, which it never was since I bought the car!
      www.instagram.com/snwmble
      #snwmble
      Current:
      '05 BMW M3 - Silver Grey/Imola Red
      '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
      '15 Mini Countryman - Blazing Red/Carbon Black
      Past:
      '01 Audi Allroad - Light Silver/Platinum Saber Black
      '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
      '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
      '90 BMW 325i - Schwarz/Tan sport *Sold*
      '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
      • supernaughtIX
        • Apr 2007
        • 260
        congrats
        • audiquattrot
          • May 2008
          • 3836
          Originally posted by supernaughtIX
          congrats
          actually i take that back. lol
          So the problem did get a bit better after the u-joint replacement, but I'm still getting a steering wheel wobble (more pronounced when applying the brakes on occasion at highway speeds).
          I replaced all 4 rotors and pads, and the brake pedal is firm and good. Its just on occasion the steering wheel will shake and shimmy/vibration even just rolling.
          Power steering rack play you think? I also read somewhere that there is a guibo connected to the steering column? thoughts?
          #snwmble
          Current:
          Past:
          • supernaughtIX
            • Apr 2007
            • 260
            Power steering play is highly unlikely. You're more likely to see a bad balljoint or CAB.
            • audiquattrot
              • May 2008
              • 3836
              yeah I think that might be the next thing to tackle....the control arms. I couldn't imagine it transferring that much play & shimmy to the inside cabin....but i guess its likely. I've replaced the rear front control arm bushings (rubber circle), all new sway links, springs, shocks, even motor mounts thinking any one of them could be the issue. Thanks for your input btw.
              #snwmble
              Current:
              Past:
              • supernaughtIX
                • Apr 2007
                • 260
                Did you do tierods?
                All of these things can potentially contribute to vibration or alignment/pulling issues:
                bad control arm balljoints, inner or outer tierod joints, control arm bushing, wheel bearing, low tire pressure, tire damage/wear
                It can all be felt in the car, and anything that happens in the front end will be felt through the steering wheel.
                • E30Gus
                  • Jun 2008
                  • 781
                  Tires out of balance possibly. I just did a tire rotation and my front started shaking at various speeds. Went to balance the fronts and the guy said the weights fell off of one of the rims. Problem solved.
                    • 34839
                    I had the wierdest thing cause a nasty vibration/steering shake the last couple weeks: an bad CV joint. go figure!
                    • audiquattrot
                      • May 2008
                      • 3836
                      Did you do tierods?
                      yup both inner & outer tie rods i replaced last yr. Same w/ both front wheel bearings. Also filled up my tires to 36psi sunday. I'm slowly trying to rule things out....as you can see lol.
                      I'm hoping that's all it is. I know i slightly bent one or two of my Alpinas (thanks to NYC potholes)....thing is though, sometimes its' there, sometimes its' not. I would think bent wheels would produce a shimmy vibration all the time.
                      hmmm How did you pin it back to a bad CV joint? What signs did you see that were bad?
                      #snwmble
                      Current:
                      Past:
                        • 34839
                        I could hear it rattling around when driving slowly in a straight line. I swapped in another one I had, and it all went away.. the noise at low speed, and specifically, a nasty vibration/wheel shake at 75mph..
                        • audiquattrot
                          • May 2008
                          • 3836
                          yeah after driving it for the last wk, i'm almost certain its my front control arms (lollipop most likely). In stop/go traffic, i can feel the front suspension shift + clunk. Smooth roads isn't really an issue, its 40mph+ where I sometimes feel the shimmy.
                          btw, where is a good place to get iX control arms these days? I know their pricey new.
                          #snwmble
                          Current:
                          Past:
                          • audiquattrot
                            • May 2008
                            • 3836
                            btw almost 1900 views in this thread? lol
                            #snwmble
                            Current:
                            Past:
                            • NNW
                              • Apr 2011
                              • 47
                              I recently bought a control arm from bmwmercedesparts.com $183.45 shipped. Was quick to arrive as well.
                              • audiquattrot
                                • May 2008
                                • 3836
                                well my new CA's arrived yesterday ($200/each from bmwmercedesparts) ouch.. I'll report back nxt wk....hopefully this is the cause of this long ongoing issue w/ my front suspension/steering! I'm also going to drop the lower dash and try to tighten that stupid 32mm nut that i should've done from the beginning. I'll be pretty pissed if that was all it was!
                                #snwmble
                                Current:
                                Past:
