325ix registry - submissions needed!
    • 34839
    I've been wanting to create a new "registry" for the remaining 325ix's for a long, long time. I've finally had a chance to complete it!
    Eventually it will be a searchable database (year, body style, color, etc), but right now it's hosting for 5 pictures (more if you make multiple submissions) and information/stories you'd like to share on your 325ix.
    Photo Gallery of my personal 1991 325ix from 2002 to present, including information on suspension, engine, and basically anything mechanical. Additional pictures and information on converting Motronic 55 pin 1.1/1.3 to Megasquirt 2 and Megasquirt 3.
    Ideally I'd have every 325ix in the database, but for now you can help by adding yours. :)
    If you add your VIN (which will never be shared!) I want to add a VIN decoding script later on, showing a bit more detail.
    hopefully I've got all the bugs worked out.. let me know if yours doesn't work.
  • BavarianBlue
    • 27
    hmmm, sounds great man, mine isn't working for some reason though, don't see anything to fill out...
    • pawi30
      • May 2007
      • 1091
      Added myself. I hope this takes off.
      Originally Said by Bob Marley
      "BMW make pure trouble!"
      • smcdermott326
        • Jan 2008
        • 84
        I guess I get some pictures, since your registration edits require at least 1 photo.
          • 34839
          yeah, I'm going to change it so you can add a photo later, to get more registrations. that should happen friday I hope.
          are you using google chrome by chance?
          • dannyyisntt
            • 3141
            This is a cool idea!
            I'll add myself once I get more pictures of the car, or when you change it so I can add a photo later.
              • 34839
              well you'll be able to add more pictures later regardless. so if you've got at least one, go ahead and post it now.
              • 325ix
                • Aug 2009
                • 7783
                I will join up when I get some better pcitures.
                • Andrew325is
                  • Jan 2008
                  • 1212
                  I'll have to get the VIN for the diamond black 89. I noticed the info on your homepage isn't exactly accurate. There were 4 door 88's for the USA. There was just recently one on craigslist here in Portland. I called the owner and he said it was not imported, Canadian or otherwise.
                  Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
                    • 34839
                    It had to be a gray market car. There were definitely no 4 door ix's in 88 for the US. Canada is the only country to get a diving-board 4-door ix.
                    88 model year - USA, 2 door only, Canada, 4 door only.
                    looking forward to your submission :)
                    • Andrew325is
                      • Jan 2008
                      • 1212
                      I wish I had got the VIN for it. I'll have to do some more research to prove you wrong. ;) There's also specs in the 88 E30 owner's manual for US 88 4 door iX's.
                        • 34839
                        probably because the manual for US/Canada was the same.
                        I'm 100% sure there was never a 4-door 88 ix in the US, unless it was a gray market car. I've seen hundreds of 2-door 88 ix's over the years, never a 4 door unless it was canadian.
                        • dranttna
                          • 127
                          registered. good idea
                          325es/24v's/20psi/meth injection/
                          • pawi30
                            • May 2007
                            • 1091
                            Originally posted by 325iX Registry
                            Password:
                            Must be between 6 and 100 characters.
                            That made me snicker.
                            • pawi30
                              • May 2007
                              • 1091
                              Do you need a seperate username for the forum?
