ix performance difference
    • 34830
    it should pull smoothly to redline. the stock peak is what, 5800rpm? 6250 is the redline.
    • 325ix
      • Aug 2009
      • 7783
      Yeah, to me it feels as if it hits a wall and then continues to accelerate, but the rate at which it is accelerating doesn't increase any more.
      • 325ix
        • Aug 2009
        • 7783
        I can switch a 173 grey sticker Ecu into my car that came with a 153 green sticker ECU with no problems correct?
          • 34830
          yes
          • Kershaw
            • 11822
            also, if thats your 88. then you do have trunk tar. and a steel spare. both are heavy as hell.
            AWD > RWD
            • 325ix
              • Aug 2009
              • 7783
              yep, spare is 39.5 lbs. I may get AAA just so I don't have to carry it. I just did plugs, wires, an o2 sensor and coil and my car feel so much better. The cap and rotor should be here monday.
              • Kershaw
                • 11822
                or just go to a junkyard and pull a normal tire. 195/65/14 is pretty much the same size as 205/55/15.
                AWD > RWD
                • Earendil
                  • 1662
                  FYI: Peak acceleration will be at peak torque, 4300rpm. It will feel almost the same after 4300, but it will be a little less as you approach redline.
                  1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
                  2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
                  I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
                  • rustybullet
                    • 218
                    you guys might want to adjust your afm if its original high mileage one. before i adjusted mine my low end power was horrible, top end was not that great either. if i remember correctly i adjusted it three clicks clock wise which would cause it to run leaner. low end is great now and top end feels nice. engine feels new again.
                    also use a q tip with rubbing alcohol to clean the carbon track or any dust or debris.
