strut bar options
  • Kershaw
    • 11822
    strut bar options
    i've found this... and i've read that the weichers bar is mandrel bent round. so that's a plus.
    and this...
    http://www.masonengineering.net/Subpages/E30.htm
    but the mason bar for the ix looks retarded. square and no reinforcements on the sharp edges...?
    any input?
    AWD > RWD
  • flyboyx
    • 8371
    well, mason says they have an aluminum one? ask for photos. for a strut bar to really do a good job, it should have a way to mount to the firewall. unfortunately, in the case of an e30, we are cursed with having the a/c access panel in that location.
    shipping from deutscheland for the other bar will be very pricey and to me, i don't think it looks much better than the mason. generally, if you are going to shell out the cash for something like this, you would want to go with the one that is stiffest. does it really matter what it looks like?
    Gigitty Gigitty!!!!
      A Sparco strut bar is about as strong as you'll find and isn't expensive (~$130).
      • matt0300
        • 549
        Waste of money. I can't justify spending that money for the benefits of a strut bar. In my opinion I think that having ur wheels camber out is better for turning, why would u want to prevent that? I could be wrong. If I am correct me.
        • Kershaw
          • 11822
          when i bought my eta, the PO's step brother had welded a solid bar between the rear towers and made a strut bar for the front. the front bar wasnt the best i've ever seen.
          however, you could REALLY notice a huge difference in chassis rigidity when you jacked up one side of the car. it was very easily noticeable over a stock e30 chassis.
          i cant find the sparco front bar. i can only find the rear.
          http://thmotorsports.com/whiteline/w.../i-443987.aspx
          this one CLAIMS it fits the front... but uh.. the ix is different from all the others so...
          AWD > RWD
            • 34844
            you can get the wiechers bar from bavauto, it works fine. although I wish I could just get my chassis seam welded, or add a full cage..
            insert facepalm here..
            • matt0300
              • 549
              Explain why u would want to prevent ur wh out wheels from cambering out when ur turning?
