325ix swaybar end link
  • Killacortes
    • 1937
    So the bushings that are on the end of my sway bar end links are worn out and tore up. Pelican parts offers a OE replacement for cheap but I couldn't find any other places. Should I just go with OE or is there other endlinks out there I should consider
    r3v does not fuck around. First you get banned, then they shoot you
  • Killacortes
    • 1937
    i guess i just go with stock?
      • 34844
      you can use E30 M3 adjustable endlinks. sometimes they are cheaper than stock.
      • nomansland92
        • 1657
        Is this for the front or rear? I think the rear links are universal with an I but the front is ix specific. I've never heard that m3 links would fit but that would be very nice if they do.
        IX being restored here
        Ix turbo build here
          • 34844
          the rear links are the same, yes.
          • Killacortes
            • 1937
            Sweet I'll check those out!
            Edit do they HAVE to be adjustable end links or can I jus get the regular ones they are cheaper than stock ix end links!
            • 325ixa
              • Jun 2011
              • 73
              do you have part number for adjustable endlinks?
              thank you
                • 34844
                they are going to be aftermarket, so anywhere that sells performance M3 stuff.
                • mrbobian
                  • 59
                  While this has been brought up... What are the thoughts on the GC adjustable links? They sure look nice... Anyone using them? Will they even work with our cars?
                    • 34844
                    if they are for E30 M3 fitment, they should fit.
                    they're really only useful if yours are damaged (likely) or if you are lowered.
