oil pan removal
  • VRSTLE
    • Dec 2010
    • 146
    oil pan removal
    i was just wondering if anyone had taken the oil pan off with out removing the whole engine
    • 34839
    yes.. support the engine from the top, and remove the subframe.
    • MattM
      • Apr 2009
      • 931
      its not a quick or simple job by any means, no matter how you approach it.
      Full Build Thread Here
      • VRSTLE
        • Dec 2010
        • 146
        For the rear bolts there is something covering them i took the four bolts that where in it off but
        do i also have to take off the torx bolts that are on the transmission to get this cover off
        also do i have to remove the drive shaft to get the front diferential off
        • MattM
          • Apr 2009
          • 931
          your trying to get the diff off? To get the diff off you much first pull the axles shafts out. Then the driveshaft.
          Once it is unbolted (4 bolts) you may have to pry it away from the pan because its a tight sealing fit into the pan.
            • 34839
            you don't need to remove the diff to remove the oil pan..
            • jarldian
              • Nov 2011
              • 13
              as a sidebar... If I wanted to just replace the oil pan gasket, would you guys recommend that I remove the entire pan as the best way to handle this?
              • bernzpeed
                • 3917
                ah... yeah... aren't you going to clean it first before putting the new one in?
                89 E30 S52
                Transaction Feedback.
                  • 34839
                  you can reseal the pan but there isn't a gasket.
                  • jarldian
                    • Nov 2011
                    • 13
                    ?? no oil pan gasket for the IX? do the other e30 models have gaskets for their oil pans?
                    i'm leaking all over the place underneth, does that mean I just need to just replace the sealant?
                      • 34839
                      nope, yes
                      I'd steam clean the underside of the engine and verify leaks first. could be main seals, or gaskets from above..
