scratching my head on how to remove these. Is there a write up somewhere I can follow? or maybe it's really easier than it looks?
IX sideskirts
remove all the clips you can see (some are screw in), and pull. they have double sided 3M tape holding them to the car too, which doesn't like to let go. except for the lower side skirts, the 3M tape could hold the flares on pretty much by itself.. -
The front flares need to be slid back or forward to release the clips sorry I can't remember ill have to look. If remember correctly atleast, but I could be wrong. the side skirts come straight off screw clips on the bottom and tape and puch in clips along the top. The rear flare is attached with two puch in clips and screwed to the side skirt.
Hope this helps, good luck
Sent from my ADR6300 using TapatalkComment
they've all got the same clips/grommets along the top edge. you can't really slide them unless the tape's gone bad. you pretty much have to pull. I think you can try popping the clips/grommets out from behind the fenders but it won't work on the skirts.Comment
