can i drive with just one drive shaft 325ix
  • vk88ix
    • Feb 2012
    • 59
    can i drive with just one drive shaft i have a 325ix the rear one is off with it mes anything up if i drive it?
    1988 325ix sold
    1986 325e sold
    2003 honda civic
    1989 325is lsd
  • nrubenstein
    • 3148
    It's possible to drive with just the rear shaft. I don't know that I would attempt to drive further than around the driveway with just the front shaft in.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
      • 34844
      the front diff is pretty tiny - I wouldn't want to put all the car's torque through it either.
      • nrubenstein
        • 3148
        Maybe pull three coils? :p
        • flyboyx
          • 8371
          the torque split is wrong for using the front shaft only. as mentioned above, the front diff is too weak to handle the entire load of the car for any length of time. i would do it if it was a matter of being stranded in the middle of the desert and that was the only way out of there other than walking. otherwise, let the car sit until you can repair it properly.
          Gigitty Gigitty!!!!
          • catoichi
            • Aug 2011
            • 78
            don't do it! when i bought my car it was missing the rear half shafts after about 2 months of me putting off fixing it my trans died on me. my transmission guy told me it was the missing half shafts that did me in. cost more to fix my transmission and transfercase than it did to buy the car..
            Red-ish 89 325ix with dent in the door, bad paint, missing center caps, broken defrost, broken ac, p/s pump may be going, brake pad sensors missing. On the plus side i just had the trannie and tc fixed for 2 grand!!
            • Pantless Spency
              It's McRib time!!!
              • Feb 2011
              • 7283
              just curious why would you want a fwd e30?
              or do you just not want to buy the rear end parts.
              • vk88ix
                • Feb 2012
                • 59
                i ment like drive it into/out the shop
                btw rear drive line is $300 new at cost less
                1988 325ix sold
                1986 325e sold
                2003 honda civic
                1989 325is lsd
                • Chruby99
                  • May 2011
                  • 262
                  I off loaded mine from a tow dolly with the rear drive shaft removed. it beats the jack test. Long lengths of use would probably cause the silicone in the VC to start ozzing out and rendering the center diff useless. Which would probably be the end of the FWD iX
