another front driveshaft problem
  • e30forlife
    • Mar 2012
    • 583
    bought some honda moly 60. I think this should do the job. Ill be un installing all of last weeks work tomorrow and sunday:(
    91 318 s52 Swap
    -m50 manifold
    -headers
    -zf320
    -3.25lsd
    -KaMotors Intake
      • 34839
      I use copper anti-seize on the CV shafts so they slide in and out of the hub easy, and don't get stuck of course. there's not relaly a rust problem there, unless they've never been removed.
      what is honda moly 60 designed for? don't go with "should do the job" because you'll cause a lot of damage over a $20 tube of grease.
      if it's meant for a similar application and it meets the same requirements (high pressure, oxidization resistance, water resistance, etc), then go for it. if it's just a CV joint grease or something then forget it..
      • e30forlife
        • Mar 2012
        • 583
        Ok so do I need to remove the front axles and put grease on those splines?
        I know I need to do the front drive shaft...
        91 318 s52 Swap
        -m50 manifold
        -headers
        -zf320
        -3.25lsd
        -KaMotors Intake
        • e30forlife
          • Mar 2012
          • 583
          No this moly 60 is meant strictly for splines on the rear drive shaft motorcycles. It was recommended from BMW.
          91 318 s52 Swap
          -m50 manifold
          -headers
          -zf320
          -3.25lsd
          -KaMotors Intake
            • 34839
            it's not really neccesary. if you wanted, you could pop off the axle nuts, push the shafts part way in, and stick some anti-seize in there.
            they won't get destroyed like the front shaft will without lube, but there's a chance they could get stuck together with rust.
            • e30forlife
              • Mar 2012
              • 583
              Yeah but do I put grease on the splines going to the oil pan?
              91 318 s52 Swap
              -m50 manifold
              -headers
              -zf320
              -3.25lsd
              -KaMotors Intake
                • 34839
                no
                • iXe<30
                  • 143
                  Originally posted by 95BMWIC
                  Not that anyone will believe me, but I have over 15,000 miles logged without a front driveshaft.
                  Still driving it..
                  Wouldnt this kill your vc thang?
                    • 34839
                    nah.
                    • iXe<30
                      • 143
                      damn... i need to do more research on our dt.. know exactly how it ticks.
                      • Dirty325ix
                        • Sep 2012
                        • 689
                        Were can I buy the BMW motorcycle drive shaft lube that you ate talking about
                        • NickiX
                          • Jul 2011
                          • 184
                          A BMW motorad dealer
                          89 325iX - stock but overflowing with factory extras
                          85 324tdt -frankentrimmer
                          • Dirty325ix
                            • Sep 2012
                            • 689
                            I live in the middle of the rockymountains with no BMW dealer for atleast 6 hours and I need this lube to drive so any way to get it online
                            • jP4
                              • Sep 2012
                              • 168
                              Here's a link to buy Molykote BR-2 Plus multi purpose grease. I've read that this will work just fine, and it's used on airplane output shafts...and I'd say if it's good for a single engine airplane, it's good for your bimmer. And honestly...I think some Mobil 1 synthetic grease would work, too. We put it on transmission output shafts for the same purpose, to prevent corrosion on the splines and to lubricate. I would use the Mobil 1 syntho on my drive shaft splines and half shafts, too. Just my opinion.
                              • Dirty325ix
                                • Sep 2012
                                • 689
                                Nando what do you think about that
                                even though I'm pretty sure you will say get the motorcycle lube
