another front driveshaft problem
  • NickiX
    • Jul 2011
    • 184
    So I just joined the failed front driveshaft club after over two years, 50k miles, and a factory new transfercase. So hoping the year old t-case isn't also shot but I'll know in the morning. Does anyone know if the car can be driven without the front shaft? I just need to drive it to work to fix it.
    89 325iX - stock but overflowing with factory extras
    85 324tdt -frankentrimmer
  • z122643
    • Aug 2011
    • 286
    Nando has done it apparently. It should be possible but I wouldn't go far.
    [/SIGPIC]"we are so totally screwed!"
    • NickiX
      • Jul 2011
      • 184
      yeah I was hoping to hear from nando. I thought I've read somewhere that you can but I had to check.
        • 34839
        if you just need to drive it somewhere to fix it, it will be fine. I wouldn't do a 1500 mile road trip or anything but 5 miles isn't going to hurt anything.
        did you have proper lube on the splines? dust cover in place? worn shaft in a new t-case? are the splines rusty at all?
        • 95BMWIC
          • Apr 2012
          • 353
          Not that anyone will believe me, but I have over 15,000 miles logged without a front driveshaft.
          Still driving it..
          • e30forlife
            • Mar 2012
            • 583
            What does this lube you guys are talking about.... I didn't do this when I put it in last weekend :/
            Im new to these and almost have the car drive able.
            91 318 s52 Swap
            -m50 manifold
            -headers
            -zf320
            -3.25lsd
            -KaMotors Intake
            • canuck
              • Apr 2006
              • 25
              Look for Molykote from Dow Corning available online for <$20 shipped
              Must do
              • NickiX
                • Jul 2011
                • 184
                Or the driveshaft lube from a BMW motorcycle dealer. Its really close to the original lube BMW used on the ixs
                  • 34839
                  without lube, give the shaft about 6 months to live, tops.
                  the BMW motorcycle stuff isn't just similar, it's the same thing. I've never seen a BMW Motorcycle dealer though.
                  • jP4
                    • Sep 2012
                    • 168
                    How about Liqui Moly, anyone? CV joint grease -- $6 at Pelican for 100g tube. I'm putting H&Rs on my ix pretty soon and plan to inspect/grease the splines at that time. Love my ix, but I always feel like I'm walking on eggshells with those front drive shafts.
                    • e30forlife
                      • Mar 2012
                      • 583
                      do yo have to put it on the axles also?
                      91 318 s52 Swap
                      -m50 manifold
                      -headers
                      -zf320
                      -3.25lsd
                      -KaMotors Intake
                        • 34839
                        CV joint grease will not work.
                        • e30forlife
                          • Mar 2012
                          • 583
                          will this work?
                          Honda Moly 60 Paste. New 60% moly-grease formula. The contents are solid and will not separate at room temp. Recommended for gears, bearings, and other high-pressure/high-temp applications.
                          91 318 s52 Swap
                          -m50 manifold
                          -headers
                          -zf320
                          -3.25lsd
                          -KaMotors Intake
                          • jP4
                            • Sep 2012
                            • 168
                            Not sure if you're trying to differentiate the driveshaft and axle. They're the same thing. There are splines on each end of the driveshaft. Splines on the outside seat in the wheel hub and the inside splines seat in the differential. You'll want to grease these splines to prevent corrosion.
                            Edit: Ahh...my bad NickiX. Assumed you were talking front driveshafts (axles). Your talking transfer case drive shaft. *facepalm*
                            • jP4
                              • Sep 2012
                              • 168
                              Thanks nando.
