ABS Ring part of Axle
  • dubdub
    • Oct 2007
    • 295
    So I happened to be reading on E30tech and someone mentioned getting a bad axle to get their hands on an ABS ring.
    Does the ABS ring come as part of a new axle? I am fairly certain the front drivers side ring is causing my ABS fault (guessing it is cracked or something). I recently had my passenger side axle replaced and know my drivers one is not too far behind.
    Solves two issues at once... if not I want to make sure I have it on hand whenever the new axle goes in. Anyone know a part number for an ABS ring? I couldn't find it on RealOEM.
    Thanks.
    • 34839
    yes they come with a new axle. you can't buy it seperately, but it's just pressed on.
    • dubdub
      • Oct 2007
      • 295
      That's good news. Not that I cannot buy it seperately, but just that it will be new when I get a new axle.
      • flyboyx
        • 8371
        it is possible that your ring is bad but it is really unlikely. chances are you have a bad sensor or a fault in the wiring that goes to the sensors.
        Gigitty Gigitty!!!!
        • dubdub
          • Oct 2007
          • 295
          Thanks... replaced sensors and wiring previously... and the ABS cpu. Running out of things to throw at this.
