Finally got my Moonlite Motorwerks driveshaft spacer.
  • audiquattrot
    • May 2008
    • 3836
    Looks like great build quality. It's a 1/2 inch in thickness and should help in giving the new (used) shaft better bite.
    Its been almost 2 months since the car has been sitting....hopefully this donor auto transfer case I got is good.....gonna have to dissect it to mate up w/ the 5-speed
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • flyboyx
    • 8371
    hmmm.....cool product.
    to be clear, you are using this because your drive shaft started skipping in the transfer case socket?
    if this is the case, i am not sure this is a long term solution but hopefully it will get you by for a while.
    you might need to grind some of the aluminum off the oil pan in that area so the bolts will clear.
    Gigitty Gigitty!!!!
    • audiquattrot
      • May 2008
      • 3836
      Yup the guys at MM mentioned about grinding that area to clear. Not much tho.
      As far as the skipping, yes my current tc and shaft are stripped but I'm trashing both of those. Starting fresh w a new/used shaft and tc that look to be in great condition. I just wanted more surface area for it to grab to
      #snwmble
      Current:
      Past:
      • williamtii
        • Jul 2009
        • 281
        WTF I tried getting one of those last year and got no response. Tried for a couple months. I have a sweet action CAD drawing for a spacer from another dude that never got off the ground. May try it one day when I get another iX.
        • gw ix
          • 158
          Looks cool. What is the spacer made from? Aluminum?
          What do they thread the studs into the axle flange with teflon nut on the back side?
            • 34827
            no centering pin = no thanks.
            personally the thicker X5 flex disk and X5 centering pin make a lot more sense. you can add a washer or two there as well if you want maximum spacing.
            • audiquattrot
              • May 2008
              • 3836
              Yes the shaft is threaded to accept the studs that have a Teflon nut on one end
              #snwmble
              Current:
              Past:
                • 34827
                guess I can't see it in the pic? it looks like a flat faced spacer?
                • flyboyx
                  • 8371
                  perhaps the spacer goes between the original ix centering pin and ds?
                  Gigitty Gigitty!!!!
                  • Northern
                    • 5094
                    That's what I would've assumed.
                    Originally posted by priapism
                    Originally posted by shameson
                      • 34827
                      then it needs the flanges that fit into the driveshaft and centering pin, otherwise it's still centered with bolts.
                      FWIW the X5 flex disc is ~3/8" thicker than the ix one (it's really the same thing as a rear flex disc)
