Will the Racing Dynamics reproduction headers fit the iX?
  • leegf
    • Dec 2010
    • 1168
    As seen here:
    Owner of the shop mentions the following:
    "The headers are claimed to fit a right hand drive E30 and they do sweep back and hug the block pretty good. To be honest here in SoCal I have only worked on 1 Ix so I know they do have different shock towers and of course axles running to the front hubs.
    I would say they will fit, the only question mark I have is will they clear the axles.
    I have several fitment photos on my website if you want to check out some of those pictures to visualize fitment."
    Thanks all.
    E46t
    • 34844
    yes
    • leegf
      • Dec 2010
      • 1168
      cool, thanks. will it require any fabrication, or not any more than it would to fit them to a standard 325i/is?
      E46t
      • audiquattrot
        • May 2008
        • 3836
        u got an ix?
        www.instagram.com/snwmble
        #snwmble
        Current:
        '05 BMW M3 - Silver Grey/Imola Red
        '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
        '15 Mini Countryman - Blazing Red/Carbon Black
        Past:
        '01 Audi Allroad - Light Silver/Platinum Saber Black
        '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
        '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
        '90 BMW 325i - Schwarz/Tan sport *Sold*
        '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
          • 34844
          same work
          • jute91
            • Nov 2011
            • 581
            no offence, but those sucks.. too big collectors...
            i bought mine from speed-daddy.com
            but quality isnt that what i want..
            so im goin to make it myself, when it is time for that.
            here is good way to do it..
            Also found on Facebook - Juuso Tero, Tampere
            https://www.facebook.com/JuusosGarage
            • leegf
              • Dec 2010
              • 1168
              Originally posted by audiquattrot
              u got an ix?
              not yet ;)
              please explain. what experience do you have with them?
              E46t
              • audiquattrot
                • May 2008
                • 3836
                not yet ;)
                do tell!!
                #snwmble
                Current:
                Past:
                • leegf
                  • Dec 2010
                  • 1168
                  do tell!!
                  haha, too early. no exchange of money yet = don't want to ejaculate prematurely :p
                  E46t
                  • jute91
                    • Nov 2011
                    • 581
                    We have build folk racing cars with my dad and we have usually made everything by ourself.. Head porting, intake manifold, exhaust manifold and gearbox.. Here is picture of our Mk2 escort rallycross car.. 220hp 240Nm with 2.0 litres and 48mm DCOE webers
                    So heres a little theory if you can understand my english..
                    BMW uses 1 - 5 - 3 - 6 - 2 - 4 firing order in m20 engines which is typical for inline-6 engines.. they also use 3-1 exhaust manifold instead of a 6-1 manifold. that simple, its hard to make 6-1 manifold.
                    Because most important thing in making manifold is its lenght..
                    every single pipe in manifold should be "nearly" same lenght..
                    i mean they should not be same lenght but they should be in 10-20mm compared to shortest to longest. Thats because
                    every pipe has resonance part compared to its lenght. and if your
                    every pipe is same lenght, it makes huge torque peak that last max 1k rpm area.. but when you have different lenghted pipes, peak is little lower but then its on wider rpm area..
                    when exhaust gasses leave cylinder head through exhaust valve,
                    it temperature start to fall immediately.. then it happens what it
                    does with every material, when talking about heat transfer..
                    the density and travelling speed starts to fall down..
                    and when exhaust valve closes, it makes vacuum behind gas "pillow"..
                    you can see temperature of this picture..
                    so about that vacuum behind gas pillow, or what it is called..
                    its has big role in collector..
                    collector has many other things than only collecting gasses together..
                    It decided how your exhaust gasses will flow on later part of exhaust.. if you make too big outlet pipe on collector, your exhaust speed will crash down. also if your collector joining angle is too soft, it will also crash... and vacuum behind gas pillow wont suck gasses from other cylinders like it should.
                    you can see from here what happens when your exhaust gasses
                    gets into bigger diameter place
                    just search exhaust flow simulation to youtube.. theres some flow
                    measurement videos..
                    but how collectors should be done is..
                      • 34844
                      yay! somebody else who's as much of a nerd about header design as me!
                      actually, you're a bigger nerd in this case, but that's a good thing :D
                      • jute91
                        • Nov 2011
                        • 581
                        thanks :D i dont know is it good or bad, but cars are my life :D
                          • 34844
                          Also, i should mention the RD reproductions, and the ones you got are not the same - those are from china, and i agree the quality is not good.
                          The RD repro headers are actually made by RD in italy. Although they arent perfect, you wont do a whole lot better for the price.
                          • jute91
                            • Nov 2011
                            • 581
                            it doesnt matter me how does it look outside.. exhaust is that kind of part that "interior" matters for me.. because i want to make it technically better
                            • jute91
                              • Nov 2011
                              • 581
                              Granted this is not the first time we have looked at the OS Giken’s TC24-B1Z, but seeing it’s further been refined from last year’s Nostalgic 2 Days show, I thought I’d dedicate a little post to it as it’s simply, a work of art. It was back in the late seventies that Okazaki-san from OS …
                              heres manifold that looks pretty good by its shape and lenght.. collector is also pretty good
