iX master cylinder piston size
  • Roysneon
    • 4505
    Does anyone know what the size of the iX's stock brake master is? Anyone know of a larger one that will give a stiffer pedal that will bolt up to the iX booster?
    I know that M3 and 750 e32 are upgrades for non-iX cars but they won't fit on our boosters. I think that e36 masters will fit out boosters but once again I have yet to verify the piston size on the e36 ones.
    Originally posted by mbonanni
    I am a pursit now.
  • jute91
    • Nov 2011
    • 581
    It says 20mm... :)
    Also found on Facebook - Juuso Tero, Tampere
    https://www.facebook.com/JuusosGarage
      • 34844
      Its the same size as a regular e30
      Im pretty sure the 750 e32 is the 25mm vversion.. i had one, ill have to look
      • Roysneon
        • 4505
        But does the 750 one fit the iX booster stud pattern?
        I am a pursit now.
          • 34844
          Yes.. it's the E32 booster that's basically the same as the ix.
          • Roysneon
            • 4505
            Awesome. I have a brake booster from an e32 735, I just didn't think to look at the master cylinder when I pulled it. My car isn't an iX, just 24v swapped. I'm doing an e30 M3 5 lug swap and want to go with a master cylinder closer to the e30M part that will fit the e32/iX booster.
            I am a pursit now.
            • stonea
              • 2892
              I'm interested if you can do anything with the E36 one?
              My Garage
              Feedback
              Instagram: Stone.Hopkins
              • Roysneon
                • 4505
                Apparently so. I'm gonna have a look at a car someone I know is parting out later this week to compare.
                I am a pursit now.
                • Roysneon
                  • 4505
                  I'm going to pick up a used e34 master cylinder and fluid reservoir to test fitment soon. Will report back with my findings.
                  I am a pursit now.
