Got mine too!!
  • anonymous alias
    • Jun 2013
    • 66
    Got mine too!!
    been seeing what issues, fun, and mods yall have had with your ix's, now i got my own. i know i will need a lot of advice, i dont have a garage to work in, or much experience with DIY's but still willing to learn and will try. Wish i was some one like Nando things would be a little easier lol :)
    think my exhaust system needs some work, its pretty loud. would like to replace plugs, wires, and hoses.
    the PO maintained front diff replaced in 2010 because it locked up on another PO, right and left control arms in 2012, front inner/outer cv boots in 2012, rear cv shaft in 2012
    anything that i may need to look into besides the timing & water pump transfer case? i plan on getting that checked/repaired soon.
    I just would like to have it running more effeciently with a more power
  • nomansland92
    • 1657
    Congratulations on the new Ix, and ya keep up with the timing belt on these since there an interference motor. Also with the the Ix you'll want to grease the front drive shaft every year, theirs some special grease but I always forget what its called. The splines that go into the diff are pretty much the weakest link so its a good idea to check them and grease.
    Also i wanna see some pics so post them up!
    IX being restored here
    Ix turbo build here
    • anonymous alias
      • Jun 2013
      • 66
      Cool thanks, I wish I could do as many mods to my ix as the other E30's. Kinda considering purchasing an I/IS.
      • supernaughtIX
        • Apr 2007
        • 260
        There's not much you can't do to an iX.
        Motor swaps need more work with maybe adding a custom cut/welded pan, but doable.
        5 bolt swaps are still in the works by a few people but possible.
        Suspension options are limited compared to rwd e30s but there is plenty enough to get the ride and stance you want.
        88 325 IX DiamantSchwarz - TOURING - waiting...
        89 325 IX AlpinWeiß - Gone
        88 325 IX DiamantSchwarz - Parted
        89 325 IX RoyalBlau - Parted
        88 325 IX RoyalBlau - Gone
        • jute91
          • Nov 2011
          • 581
          nothing is impossible.
          i've done couple mods to my ix and will do more!
          Here's mine
          And here is my friend Matti, known mw044 in here, his blog is in e30tech
          Also found on Facebook - Juuso Tero, Tampere
          https://www.facebook.com/JuusosGarage
          • nomansland92
            • 1657
            Boost it!!!! It will solve all your needs for power
            Ix turbo build here
              • 34844
              this isn't really true.. except that you can't buy cheap Chinese shit on ebay and bolt it up, you can do any of the same things to an ix as you can to a standard E30. GC makes a full suite of ix suspension parts.
              I still haven't finished it yet but I still think a rwd E46 front swaybar will work on an ix for a dirt cheap upgrade.
