Steps to change transmission mount?
  • BingM3
    • 863
    Can anyone give their input?
    Thanks
    • 34844
    it has to be pressed in. so, you need to remove the transfercase, and take it to a shop who's competent.
    • gath
      • 577
      :nice:
        • 34844
        I didn't mean that as an insult - somebody who's clueless can break off the ear of the transfercase. seen it happen before. that would really suck. :(
        • Poorboyz
          • May 2012
          • 2117
          Are we talking transmission or ix transfer case? I'm confused. There are no mounts in a transmission that need to be pressed in or out.
          Sent from my Galaxy Nexus using Tapatalk 2
          Rebuilding since 07/06/2016
          Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
          Poorboyz Feedback Thread
          • Northern
            I like cupcakes & sh!tboxes
            • 5265
            I think thats why it was assumed he was talking about the transfer case.
            Originally posted by priapism
            Originally posted by shameson
            • 1E30iX2NV
              • Dec 2012
              • 26
              ok here is the scoop ....you need to extract the mount as carefully as possible
              the housing is aluminum and it can break if too much pressure is exerted on it
              i advise reciprocating saw and cut it out . then youll need a pressing tool claw type
              its very tricky .....lube the mount up and clean the sleeve well . slowly n slowly watch it .... stop if its goes in crooked
              the tc must be removed also ...i know bmw made the special tool for all this but good luck finding it ....i used porsche tools from my shop ,,,,german is german ya know
              one more thing ...if the TC is coming out you midas well rebuild or reseal that thing ....
              best advice i can give you ..
                • 34844
                the mount on the ix is built into the transfercase, not the transmission. it has to be pressed in.
                • imwhyteyo
                  • 1165
                  does anybody know of any polyurethane, or upgraded inserts? ill be doing mine shortly, and was thinking perhaps i could make one, or use one of similar dimension and craft it to work with a sleeve, and bolt-through.. any thoughts?
                    • 34844
                    the problem is the main bolt that holds the transmission threads into the bushing. so you'd have to recreate that somehow. it also has a "key" that interfaces with the transmission bracket.
                    another way would be to fill in the voids with some sort of polyurethane.
