Project: Lela! (she loves it on all fours :) )
  • z122643
    • Aug 2011
    • 286
    #31
    I take it you like the color red? Just a guess
    [/SIGPIC]"we are so totally screwed!"
      • 34847
      #32
      a little bright for my taste but I can totally respect you for doing basically a ground-up resto on an ix! looks great!
      I have the same bar. Bavauto sells a bright chrome version of the same thing.
      • Nisse Järnet
        • Aug 2013
        • 1221
        #33
        This is the 664whp manifold btw :-) http://www1.garaget.org/archive/53/5...89-2327498.jpg
        E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
        E30 M50 6 spd 764whp @ 24psi.
        E30 M20 6 spd 675whp.
        • imwhyteyo
          • 1165
          #34
          Lol.. well much inspired by yourself.. take a bow. And as for the red.. I do want a little cleanliness and flashyness.... and i wasnt looking to keep the duller tones or the typical black spray overs... your engine bay is choice. after all I couldnt copy you entirely ;)
          • Ray Smoodiver
            • Jun 2004
            • 8809
            #35
            Loving this so far, awaiting more!
              • 34847
              #36
              yeah, actually I have a similar color scheme - mostly because I got the strut bar first. :p
              I wonder if yours will fit directly. Mine wasn't even close - had to rebuild the mount brackets on both sides. it was like an inch too wide. but that was like 10 years ago..
              • imwhyteyo
                • 1165
                #37
                So I finally got a little more work done. It's been a while... been having trouble finding time to get to the garage.
                Got the flywheel torqued.
                Mounted the front differential after cleaning and changing seals.
                Finally put the clutch kit on.
                Engine and transmission getting ready for sex. And fusion lol.
                I also finished my clock project!
                I'm heading down to the garage today to start tinkering with some more things. I'll definitely remember to take plenty of pictures this round, I'm actually enjoying this thread.more myself as a record keeper. It will be nice to see the final transformation. Soo many parts.. soo many ideas.. soo many little projects lie ahead. This will be one for all you kids to enjoy!
                • imwhyteyo
                  • 1165
                  #38
                  So I got down to the garage but I realized the place was getting more and more cluttered, so I spent the good half of the day just re organizing shelves and cabinets. Went through a bunch of old bodywork supply and paints and parts and created a ton of new trash. It really needed it. What very little I did get done was this:
                  Removed the manifolds so I could fit the turbo manifold better/tighter than with the engine in the car:
                  Used all new copper coated hardware, sealant, and anti seize:
                  Attached the wastegate and mocked up a dump Tube (might recirculated this into the exhaust.)
                  Installed the exhaust manifold setup on the engine with new copper hardware, copper sealant, and Copper anti seize for a good clean seal and excellent fitment.
                  Also mounted my Brite ass transmission.
                  Got to test fitting my custom polyurethane engine mounts with the isolators and sheilds. With new hardware of course. ;)
                  And started with the removal of the automatic pedal assembly. Which turns out to be a pain. My steering wheel is being a pita to pull.. everything else is just tedious and difficult doing partially up side down.
                  Oh.. I also got started on my Germany roots/motor sports tattoo. Only the outline for now :)
                  It's a family thing by right.. my great grandfather hails from Stuttgart, germany. My great granmother, from frankfurt Germany, both has escaped during the war to Canada then America to start my beloved family. My great, and grandfather, along with most of my uncles are avid European motor sports enthusiasts.. which has gotten me into it starting at just age 14 to now, 28, with a lot of room to learn. Never stop learning!
                  • serdar255
                    • Feb 2013
                    • 395
                    #39
                    I have a quick question about your manifold adapter. What diameter tube did you use and where did you get the flanges that bolt to the original manifold?
                    I want to make one of those, you know, for fun haha ;)
                    Project is going good, cant wait to see it finished.
                    image (10) by serdar.gurhan, on Flickr
                    PM me for custom shift knobs and stickers!
                    Originally posted by marshallnoise
                    You ain't done working on a car unless you are bleeding.
                    • imwhyteyo
                      • 1165
                      #40
                      Flanges were actually chopped up from an old set of smashed up headers. WG flange can be had anywhere.. most others can too. I'm pretty sure it's
                      2" I'd header piping.
                      • imwhyteyo
                        • 1165
                        #41
                        Got to the transfer case finally all cleaned and sealed.... and finished swapping the pedal clusters. At this moment all I have to do before reinstalling the engine is attach the clutch master cyl. Hard line back on. I'm going to swap the old ACC core for one that's not damaged. The old one had a leak. Anywho... pics!
                        Got a main outer gasket, and this is the last seal I had to do after showing you how to do the other two.
                        Cracker the bolts all about 1/8th of an inch all the way around , hitting the bolts with a rubber hammer to separate.
                        Once it's apart from the two aligning pins you should have your case exposed.
                        Pull up all the old green gasket and throw away. (Don't Foret about the middle hex nut gasket on install!!)
                        Remove this gear to get the chain off.
                        Then remove this assembly after moving the chain. This will expose the main shaft with a c clip. This shaft has more potential to vibrations, making it a common area for seal failure.
                        Got our seal ready. Pull out the old one any way you can, be I g careful not to score up the wall of the seal. I have a seal puller, but any pick or hook can snatch it out
                        Clean every removable part and transfer case covers to remove lots of old debris! You'll be surprised how much you fin on your rag.
                        After installing the new seal, you can put the old seal in also, double stacking them to 1, reduce shaft play, and double your sealing efforts. Install the second seal backwards for later removal.
                        Reinstall shaft w/ c clip after doubling seals.
                        Install in opposite order from removal, scrape old gasket surface, and install new gasket. Don't forget the small single gasket for the center nut.
                        Tighten everything up in a cross like pattern so everything seats evenly.
                        All done! Ready to go back on the motor.
                        Some people would fill the transfer case with the fluid at this point, but I will be doing all my fluids at once while everything is installed further down the road. It's easier for me to log all at once, what type of oil is going Where, and the amounts they took considering every drivetrain unit has been completely dried and cleaned inside.
                        • imwhyteyo
                          • 1165
                          #42
                          Also got the pedal cluster finished. This was a big project in itself.
                          You have to remove all steering area trim to make things easier on yourself. Then remove the steering wheel as well.
                          Remove booster assembly, and remove steering shaft half from knuckle and guibo. Knock out the steering cluster so it hangs with the wires. Their are 2 aligning ears on each side you should make note of before removing so you'll know where you'll have to hammer the rounded studs with plastic washers back in.
                          Before:
                          • kid325e
                            • Sep 2007
                            • 6422
                            #43
                            After?
                            Getting all sorts of excited for the snow to fall. Almost want to throw my Dinan iX springs and some Billy HDs on. Can't forget mudflaps and fog lights.
                            Sent from my Nexus 4 using Tapatalk
                            clutchCTRL!
                            Move with a purpose.
                            - 1991 325iX 4dr/5spd
                            - 2000 323i AT
                            2016 Mazda CX3 Sport AWD
                            • imwhyteyo
                              • 1165
                              #44
                              shes on hold at the moment, pedals have finished, i started to fix and rearrange the wiring and things in the engine bay, currently indulged in megasquirt standalone at the moment. will have lots of updates to follow. ill grab as many new pictures of things as i can while im down at the shop tomorrow. drilled/slotted brake rotors came in, ordered robertK seat brackets for powered/heated e36 seats installation. looking for options for e36 rear seat installation. going to remove the entire interior, minus the dash to get this going.
                              of course all after i finish the repairs in the engine bay. currently looking for cheap adhesive heat shields, and a turbo blanket. also if anyone has an e46 they are parting out, let me know, i will need to snag some parts from it for a later project ;) OH BOY you're all going to be very excited when i finish this car!
                              • FastAndLight
                                • May 2012
                                • 62
                                #45
                                I installed manual heated vaders in my 88 ix and they are awesome. I haven't hooked up the heating yet, but I will get to that eventually (probably just in time for summer).
                                I slid the brackets under the carpet to get a bit more room and for a cleaner look. I just cut some small holes for the bolts to protrude through.
                                It took some muscling and sweat to get everything just where I wanted it, but the seats are so much better than my stock ones.
