E34 525ix info
  • Nisse Järnet
    • Aug 2013
    • 1221
    E34 525ix info
    I read alot on E30tech and tried to register but i never get approved..
    Anyway i found alot of interesting info there thanks to sharing members, so i have a bunch of E34 525ix parts if anyone wants info, measurments etc. i have all the drive train parts x 2 :)
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
  • DC2NoVA
    • Feb 2013
    • 96
    same here :(
    • Teknik22
      • Aug 2013
      • 10
      i never got approved either
      • flyboyx
        • 8371
        that forum has gone down the tubes. :(
        Gigitty Gigitty!!!!
          • 34844
          do you have the motor mount arms/brackets?
          • DC2NoVA
            • Feb 2013
            • 96
            what a shame, so much great info on there
            • Nisse Järnet
              • Aug 2013
              • 1221
              No not at the moment, but i can get them :)
                • 34844
                nevermind - I got pics of it. I'll repost them later, but they will not work at all with the E30 ix front subframe. :(
                • Nisse Järnet
                  • Aug 2013
                  • 1221
                  OK, do you know if the best option is e34 m50 rwd mounts? Besides making your own :) I will start mocking things up in the car in september-october i hope.
                    • 34844
                    they are close but they look about 2" too far forward.
                    a guy on E30tech brought up a good point - you could make your own mount "towers", which are the brackets that bolt to the subframe, which sandwich the mounts to the mount arms themselves. you could make them so the center hole was 2" further forward and then RWD E34 mount arms would work.
                    I don't know what other people have used - custom?
                    another thought would be highly modified E30 ix mount arms but I think they get in the way of headers.
                    • Nisse Järnet
                      • Aug 2013
                      • 1221
                      Ok thanks! Looks like i will get rwd mounts and try them out!
                      Yes that seems pretty easy, i might move the engine back 1" or so.
                        • 34844
                        Have you looked at where the stock motor is?
                        I dont think you can move the motor back unless you modify the firewall. The m20 is already pretty much smashed right next to it. I think bmw already moved it back from the rwd position, although i havent measured it.
                        Even the stock position may be a challenge when you try to hook up the heater core hoses.
                        • Nisse Järnet
                          • Aug 2013
                          • 1221
                          Yes but i think you can move it back a bit with removed insulation and a gentle touch with the sledge hammer :-)
                          Im not running stock intake so heating hoses fit.
                            • 34844
                            I take it you are using the E34 transmission and transfercase as well?
                            do you have any spare E34 ix oil pump suction tubes? It's the only piece I'm missing and when I talked to people in Germany they said they just threw them away.. and they are NLA. :(
                            I hope you have front CV shafts, those are a bitch to find!
                            • Nisse Järnet
                              • Aug 2013
                              • 1221
                              Yes, all E34 parts.
                              No i lack the oil pump and tube at the moment but i will get them. U want one?
                              Yes i have two front cvs and two more on the way :-)
