Subframe Question.
  • z122643
    • Aug 2011
    • 286
    Subframe Question.
    I am preparing myself to do the rear subframe bushings, but have re-discovered how much rust I have down there.
    Is the rear subframe unique to the iX? Or can I collect a rear subframe from another (cali) E30?
    [/SIGPIC]"we are so totally screwed!"
  • 95BMWIC
    • Apr 2012
    • 353
    REAL OEM lists 2 part numbers for the rear axle carrier when discussion the 325i and the 325ix
    IX part number 33311135546
    found here:
    http://www.realoem.com/bmw/showparts...13&hg=33&fg=30
    i part number: 33311135456
    found here:
    Personally I do not know of the difference - but it may be subframe bushing carriers (I do know the subframe bushings are different - but not sure what may be size diameter?)
    • JixE30
      • May 2013
      • 19
      They are different, but also interchangeable. You will need to add spacers to the bushings and diff.
      • spdracrm3
        • Sep 2009
        • 959
        only difference "is the bushings" once you press the subframe bushings out they are the exact same part, install 325i bushings it fits that car ,install IX bushings its now an IX subframe .......as it comes with the bushings thats the reason for different part #'s
        Angus
        88 E30M3 X2
        89 325IX
        92 R100GS/PD
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          My ix is using an "I" subframe, the difference is in the bushings/top washers, and the diff ear mount tabs.
          Originally posted by priapism
          Originally posted by shameson
