clutch/flywheel differences?
  • imwhyteyo
    • 1165
    are there any differences in a normal m20 clutch and flywheel vs. the IX clutch any flywheel? i see companies selling them specific, but im curious if its the same thing just marked up.
  • AndrewBird
    The Mad Scientist
    • 11898
    Real oem shows that the clutch disk itself is the same, but the pressure plate is IX specific. The flywheel looks to be the same dual mass as 325i dual mass flywheels. You could probably swap to a single mass 325i flywheel though and run all 325i components.
    • z122643
      • Aug 2011
      • 286
      Dual mass?
      [/SIGPIC]"we are so totally screwed!"
      • spdracrm3
        • Sep 2009
        • 959
        yes clutch disc is the same but the pressure plate is stronger (almost same pressure as M3) hence the different part #, some have used a standard 325i clutch w/ no issues.
        the IX didnt used the dual mass flywheel ,its just the same as a standard 325i also
        Angus
        88 E30M3 X2
        89 325IX
        92 R100GS/PD
        • imwhyteyo
          • 1165
          It's already a single mass. Everything physically appears to be the same as my other m 20 clutches, I just wanted to make sure there isn't anything I'm missing. I've actually got an 8lb flywheel, with a spec stage 3 6puck, in my IX and It's working just fine.
            • 34844
            Originally the ix pressure plate was slightly stiffer, but i believe they merged part numbers.
            In any case, its definitely single mass and standard parts work fine.
            • imwhyteyo
              • 1165
              This question was originally in hopes that youd chime In.. Thanks kindly. Glad you could make it I need your number bud, sheesh!
              • AndrewBird
                The Mad Scientist
                • 11898
                Interesting as RealOEM shows it as being a dual mass and a different part number than the single mass 325i flywheel. I wonder why?
                  • 34844
                  I dont know, its not dual mass and never was. Afaik only the pressure plate was different.
                  • imwhyteyo
                    • 1165
                    yeah was definitely only a single mass with the two IX ive examined and taken apart.
