Front top strut plate/camber
  • duffyboby
    • Oct 2013
    • 75
    Hi guys i found that i have some wierd negative camber numbers up front, one is -0.3 degrees and the other one is -0.4 degrees, could this be my top plates are done or something else? Im debating between buying stock top plates or adjustable camber plates from ground control, the latter are quite more expensive than stock, whats your take on this?
    88' 325iX 126k
  • nomansland92
    • 1657
    That sounds completely fine, being off 0.1 per side is pretty close, last time i check my Ix was like -2.0 per side being lowered. I believe factory is with in -1.5 or something like that.
    IX being restored here
    Ix turbo build here
    • nickmcc92
      • Dec 2012
      • 442
      Those are good camber numbers. Mine is driver side -1.7 passenger -.05 and I can feel a difference when I'm driving.
      • duffyboby
        • Oct 2013
        • 75
        sorry guys i actually forgot to mention that these number are over stock, and my car is not lowered, i can see the camber when i look at it! and i also have irregular wear on my front tire, im starting to think im a paranoiac :p
        88' 325iX 126k
          • 34839
          Check your toe settings.
          • nickmcc92
            • Dec 2012
            • 442
            Those are good camber numbers. My car was hit on the front left that's why my numbers are off and my car is on stock springs, not lowered.
            • duffyboby
              • Oct 2013
              • 75
              Ok good ill stop worrying about it, thanks guys!
              88' 325iX 126k
              • duffyboby
                • Oct 2013
                • 75
                Would moog k9549 fit as a top plate for the front of the ix, on rockauto it is listed for the iX AND for the i... Dont know which is right
                88' 325iX 126k
                  • 34839
                  if they list it for a RWD E30 it's not going to fit an ix.
