I picked up a 91 325ix Auto recently and didnt realize the front driveshaft was completely missing. The splines on the transfer case were good, and I drove the car home over an hour on the highway. From what I read, that means the VC is working just fine. The only thing I noticed was a vibration in the drivetrain, which I noticed the transmission/transfer case mount is pretty worn out.
I installed a front driveshaft this week and there is a loud clunk/clack sound under acceleration. Its pretty bad. AWD does work and I put a jack under the rear end and the car did move slightly forward with a bit of throttle.
Considering I am able to drive the car without the front driveshaft in place I have ruled out the VC. I read about the possibility of the chain/gears in the TC being worn and slipping. I have not checked the fluid level but I suspect it could be low.
Am I on the right track? Any other ideas?
