Trasnfer case chain slipping? Clunk/Clack Noise from TC
  • audiquattrot
    • May 2008
    • 3836
    Originally posted by flyboyx
    i agree with audiquattrot. i have had a few ix's in my day making noises like that. for me it was always the connection between the front ds and tc.
    same here. I've been down this road several times myself.
    OP, i would try to get underneath the car, and grab a hold of the front ds, and try spinning it w to see if there is actual play where the ds & tc meet. You should be able to tell at this point if its stripped or not. There shouldn't be any play where the two meet.
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • Josh1254
      • Sep 2013
      • 426
      Thanks for the ideas so far.
      I installed the driveshaft last week and it had no play in the splines. It felt like it fit perfect. Before I installed it I would start it up and put the transmission in "D" and the TC front gear would rotate, I would go to "N" and it would stop. Then went to reversve and it would rotate again. This is while the brakes were applied with no front driveshaft. So that means the chain was working, but once I accelerate (with the driveshaft now on) something slips/clunks like crazy.
      The car was driven only short distances for the past several years without a driveshaft. The previous owner knew very little about the car so I assume the TC is low on fluid. I just havent had the time to check yet. The diffs are matching 4.10 ratios. The tires are all the same with similar tread wear.
      Ill double check the splines for play and see if I have any fluid in the TC.
      • Josh1254
        • Sep 2013
        • 426
        I went outside and took a quick video. This should give you an idea what the noise is.
        • 101
          • Jul 2011
          • 764
          Any update on this? My IX is doing something similar.
          I have fresh guibos on both front and rear drive shafts but I haven't pulled the front shaft back out yet to look at the splines (which looked pretty good when it was installed 75 miles ago).
          101
          The E30 collection:
          1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
          1987 325is - Delphin / Black Sport (son #3's)
          1987 325i Convertible - Triple Black
          1989 325iX Coupe - Diamondschwarz / Black Comfort
          1990 325iX Coupe - Sterling Silver / Grey Sport
          1981 Fiat 124 Spider 2000 - Green / Tan
          1998 Volvo V70 GLT - White / Tan
          1998 Volvo S70 T5 manual - White / Taupe
          2001 Ford Windstar - Silver / Grey (parts hauler)
          2006 Lexus GX470 - White / Tan (tow rig)
          • The Dark Side of Will
            • Jun 2010
            • 2796
            My dad's '90 iX started doing the same thing; pull the driveshaft and find that the splines are pristine = Chain.
            • 101
              • Jul 2011
              • 764
              I'll definitely do that very soon.
              On a positive note my car DID pass the jack test.
              Since removing the front driveshaft on an automatic IX also requires removing the auto transmission dipstick tube from the pan and making a mess, I'll wait until its just a bit warmer outside to do this.
              101
              The E30 collection:
                • Jun 2010
                • 2796
                It didn't for me working on my dad's car...
                • Josh1254
                  • Sep 2013
                  • 426
                  I don't have any updates. I sold the car to someone who planned to have it fixed. It was not the splines, they were perfect. It must have been inside the T-case.
                    • 34839
                    huh? no it doesn't. I did it several times.
                    • 101
                      • Jul 2011
                      • 764
                      Gents:
                      I stand corrected :o. I pulled the shaft tonight. It required removing the centering pin holder (or whatever its called) from the driveshaft flange, sliding it and the guibo out, then sliding the shaft all the way forward. There is one certain position where it will clear the ATF tube and come out.
                      The splines are pristine. There is quite a of noise and play when moving the front output sprocket back and forth. FML
                      On top of everything else -the rest of the rear brake line that I didn't replace this summer burst on the way home, I have an unidentified coolant leak at the front of the motor and I need to replace the control arms and bushings.
                      Seriously considering cutting my losses and moving on.
                      101
                      The E30 collection:
                        • Jun 2010
                        • 2796
                        You can patch, order or make a new brake line.
                        Rear control arm bushings? All of the parts are available... it just takes labor to install.
                        If you don't know when the timing belt was done, then you should fix the coolant leak while you're replacing the timing belt ;)
                        • 101
                          • Jul 2011
                          • 764
                          yup - I did all the brake hard lines and rubber hoses from the middle of the car back as well as the entire fuel system. I thought I might get another year out of the front section of that long brake line. I should have known better.
                          Fronts. I knew the front bushings were gone but in addition 2 of the ball joints are toast. I'm not a fan of the "IX parts price premium". The rear bushings are looking a bit tired too. I can't imagine what a joy that job is going to be as the fasteners are as rusted as the others on the car.
                          I just did the timing belt, water pump and all the large coolant hoses. Something is leaking above the front subframe so I guess I've either got a leaking water pump, something from the thermostat housing or one of the smaller hoses on the way out.
                          I was in a pissy mood yesterday with all of this happening plus the transfer case finally showing its true colors. I think I'm going to let it sit for a while before I start throwing money at it again. It would have been nice to drive the IX this winter while the rest of the E30's are asleep.
                          101
                          The E30 collection:
                            • Jun 2010
                            • 2796
                            iX ball joints are available separately... part numbers have been posted on this forum several times.
                              • 34839
                              man, we really need to solve the issue of the chains being out of production. :(
                                • Jun 2010
                                • 2796
                                Working on it; have a promising possibility ;)
