iX skirts removal, surprise under there
  • duffyboby
    • Oct 2013
    • 75
    I am going to be removing my iX flares and skirts this summer for a full repaint of my car, was wondering what kind of surprises i can expect to find under there..?
    88' 325iX 126k
  • audiquattrot
    • May 2008
    • 3836
    keep an eye underneath the front fenders. if they are original, they have a tendency to rot out under there. I had to replace both of my fenders when i did a respray....the rust wasn't apparent until the flares were removed.
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • duffyboby
      • Oct 2013
      • 75
      and how bad was the rear arches, i already know that my rocker has holes, but the bigger job would be the rear fenders, which i hope i dont have to!
      88' 325iX 126k
      • nomansland92
        • 1657
        when i pulled my flares my fenders were destroyed and the rockers were pretty bad but surprisingly my rear arches were not all the bad, they just needed sanded and filled.
        IX being restored here
        Ix turbo build here
        • Nisse Järnet
          • Aug 2013
          • 1221
          What do u guys use to replace the double sided "tape" with when mounting everything back on?
          E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
          E30 M50 6 spd 764whp @ 24psi.
          E30 M20 6 spd 675whp.
          • Frog
            • Jun 2010
            • 980
            kilo or 2 of coke?
            Winner winner chicken dinner?
            My Seller Feedback Thread
            • 325ixa
              • Jun 2011
              • 73
              this and primer.
              • Nisse Järnet
                • Aug 2013
                • 1221
                Thanks!
                My clips are kinda broken, what type of clips is used to hold the flares? A13011?
                • flyboyx
                  • 8371
                  71103 into the body. 11453 is similiar but doesn't look quite right.
                  Gigitty Gigitty!!!!
                  • Nisse Järnet
                    • Aug 2013
                    • 1221
                    Thanks, i just cut of as many clips i could get to and finally i got the skirt and rear flare off :)
                    Dirt...
                    Full of shit
                    Theese looked like A13011 but i just cut them off :P
                    • flyboyx
                      • 8371
                      there are some of those, but i think for the side skirts. i assumed you were talking about the ones that go into the green inserts that go into the holes in the fenders.
                      Gigitty Gigitty!!!!
                      • flyboyx
                        • 8371
                        this is how i took the fender flares off:
                        first, i used a carpet knife to cut the foam tape between the body and flare. by looking at the back of the flare, you can see that the connectors are slotted into the plastic. i just rotated the flare on the arch in the direction to unseat them from their mounts. this left all the connectors in the body and released the flare. i also dumped some baby powder in between where the flare and body meet so i wouldn't have to compete with adhesive from the tape. it worked pretty good and i didn't break any clips. seems like i had to take the bumper off if i remember right.
                        for the a13011, you can take a punch and push the little center dowel piece through the connector and the outer mushroom portion will just slide out of the hole.
                        Gigitty Gigitty!!!!
                          • 34839
                          Use the tape. It does much of the work holding it on and also seals it. You put them on after finished paint, not over primer. The flares should be painted off the car.
                          Put the tape on the flares, pull just enough of the backing so you can grab it, clip them to the car, line it up, then pull the backing strip. The paint should be clean when you do this.
                          • 325ixa
                            • Jun 2011
                            • 73
                            i meant 3m liquid primer for the tape.
