Ix rear drive shaft removal
  • Hares1370
    • Oct 2013
    • 16
    How do I remove the rear drive shaft from my ix. I've got all the bolts out but it's not dropping out. I'm trying to replace my rusty fuel tank.
  • Ether-D
    • Sep 2011
    • 2838
    You have to loosen the big nut and compress the whole thing.
    Originally posted by Andy.B
    I was born on 3/25…
    • Hares1370
      • Oct 2013
      • 16
      The big nut isn't moving any more. It's a pain in the ass
      • Ether-D
        • Sep 2011
        • 2838
        Yes, it can be a pain. Just use a pry bar and try to pry the front of the shaft rearward. It's like an inch of compression.
        I was born on 3/25…
        • Hares1370
          • Oct 2013
          • 16
          Pry the shaft forward after I loosen the nut right. Does the nut break lose once you loosen and spin by hand? Which way should loosen the nut to the passenger side or driver side. Also I'm using a pipe wrench
            • 34839
            Push the shaft towards the rear, not the front.
            • Hares1370
              • Oct 2013
              • 16
              Ok
              • Hares1370
                • Oct 2013
                • 16
                I finally got the shaft out. How you get the bolt that connects to the shaft out
