5 bolt up front
  • Nisse Järnet
    • Aug 2013
    • 1221
    5 bolt up front
    Ive seen people used E87 etc and E34ix should also work, but i checked E36 rears and they seem pretty much like stock E30ix fronts in dimensions? Anyone tried those?
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
  • flyboyx
    • 8371
    yup. the offset of e36 rear hub is too low. you will need a rotor with a very very short hat to make them work. after all the trouble the calipers will rub on the back of your wheels. also the center hole is the wrong size for front brake rotors. maybe you could use a rear rotor on the front?
    since you have e34ix parts cars, just use those. they are perfect in pretty much every way to work with e36/46 m3 front rotors. you will just need to fabricate a custom carrier bracket for use between the caliper and the strut housing.
    there is one downside to using e34 hubs. it limits your wheel choice to e36 style wheels. you will need about an et46 offset or so to tuck them under the fenders. this is perfect for me as i am going to run a set of non staggered e36 17x8 alpinas.
    btw: if you have one extra e34ix front hub laying around, i would like to get my hands on it.
    Gigitty Gigitty!!!!
    • jute91
      • Nov 2011
      • 581
      Its hard to find oem rotor that would fit in with different hub..
      I made custom center plate for my e36 front rotors with my e87 hub.. going to change stock hub back on place with welded plate and machined 5 lug pattern.. I want the front offset as low as possible..
      Also found on Facebook - Juuso Tero, Tampere
      https://www.facebook.com/JuusosGarage
      • Nisse Järnet
        • Aug 2013
        • 1221
        I found a 308mm rotor that will fit, hight is 42mm compared to stock E30 ix 36 i think? Dont know if that would work with E36 hubs but if you say caliper clearence is bad this might be a bad idea even with low rotors. Audi S3 got a 35mm rotor hight but im not sure it will accept 5/120 machining and also might be to small to fit over the hub.
        But maybe E34ix or E87 would be the best together with a ~45mm rotor hight? You should be able to fit a bigger caliper than stock with that setup, right?
        I have one spare used E34ix hub, dont think i will use it as i already ordered E87 hubs If you are not in a hurry i can send it to you as soon as the E87 hubs arrive.
        Why not use E36 rear hub instead? :) And what about caliper clearence?
        • jute91
          • Nov 2011
          • 581
          They might work well but you still need to find rotor for it or just machine center plate for it..
          • Nisse Järnet
            • Aug 2013
            • 1221
            Do you think 42mm rotor hight is to tall?
            • The Dark Side of Will
              • Jun 2010
              • 2796
              You can't just swap hubs... you need to consider the hub, rotor, caliper and wheel together as an assembly.
              • Northern
                I like cupcakes & sh!tboxes
                • 5248
                I was thinking e30 m3 or z3 for rear hubs when I last looked into how much offset would be there.
                The m3 has an obvious brake setup, and the z3 has been done before. I just don't remember what rotor/caliper is needed.
                Originally posted by priapism
                Originally posted by shameson
                  • 34844
                  IMO - just get a nice BBK, and skip the extra lug bolt. Unless there's a wheel that you HAVE to have, and it only comes in 5 lug, there's no point. a nice BBK will be far lighter than a heavy stock 5 lug brake setup anyway, and the consumables usually cost less too.
                  • jute91
                    • Nov 2011
                    • 581
                    Hub is the only thing that matters.. everything else can be fixed..
                    • flyboyx
                      • 8371
                      ^yes indeed. what coil over and upper strut mount are you running there? is that an e87 rear hub? also, tell us about the calipers.
                      Gigitty Gigitty!!!!
                      • jute91
                        • Nov 2011
                        • 581
                        Custom coilovers and yes, e87 hub. still running stock calipers..
                        • cwatt
                          • Oct 2012
                          • 275
                          Can you tell us a little more about your set-up. I assue the custom coilovers are optional and the stock strut would work. How does the E87 hub fit? Do modifications need to be made?
                            • Jun 2010
                            • 2796
                            Could a hub-centric wheel spacer be used between the hub and rotor to make up for the difference in offset?
                              • 34844
                              low offset means it pushes the wheels further out. a spacer would make it worse.
                              unless he means the hub is shallow.. not sure.
