Help
  • 2002tiiguy
    • Jul 2013
    • 467
    Help
    Unfortunately now in search of a catalytic converter. Manual transmission mine just cracked at the flex, or if anyone knows what size pipe and whether you can weld in a flex pipe. Thanks in advance
    • 34839
    I would put in a new flex pipe. the stock cats are pretty good, pretty much everything aftermarket is going to be worse.
    • 2002tiiguy
      • Jul 2013
      • 467
      just generic one even if its longer?
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        It depends on if you have strict emissions/inspections in your area. Do they require all-OEM cats? Or will they allow aftermarket ones?
        • 2002tiiguy
          • Jul 2013
          • 467
          huh? im talking about the flex joint not the cat
          • CorvallisBMW
            • 13039
            Sounds like you were asking for a catalytic converter, I guess I'm confused.
            Just go to an exhaust shop and have them weld in a new flex piece.
              • 34839
              the flex joint is part of the cat section, that's what he was asking.
              • 2002tiiguy
                • Jul 2013
                • 467
                just one of those 4" long ones im assuming? 1.75" diameter
