May have to rebuild my transmission
  • Bimmer_man
    • Jan 2013
    • 1478
    So I've been doing research on this noise coming from m uh transmission. When in neutral or downshift I hear a sand grinding noise. From what I've read it's either the throw out bearing or the layshaft bearing. Just changed the oil and it was black as night. I know that's not a good sign at all. There was some debris I attributed it to that it didn't like going into reverse. After the oil change it dose go into reverse easier.
    So I'm thinking worst case scenario. So my question is this, are the internals of a regular e30 transmission the same apart from the output shaft to the transfer case. Please let me know anyone who knows. Please no guessing I don't want to wast money on a regular transmission if it won't work.
    I'm trying to go that route cause on the west coast manual ix cars are hard to find even harder to find manual transmissions or parting ix manual cars.
    Float like a cadillac sting like a Bimmer!:)
  • The Dark Side of Will
    • Jun 2010
    • 2796
    The only different part is the rear case... but the shafts and shift mechanism are all retained in the rear case, so swapping rear cases is basically a complete disassembly of the transmission.
    • nomansland92
      • 1657
      ^That's what i thought too, but I just bought a rebuilt transmission for my ix by guten parts(built by drive-gear) and I heard there are a few difference with the gears, maybe different ratios? Anyway I know your on the other side of the states but give guten parts a call.
      IX being restored here
      Ix turbo build here
      • Bimmer_man
        • Jan 2013
        • 1478
        How much was your transmission man?
        • nomansland92
          • 1657
          I think he sells them for 1600 but don't quote me on that
          Ix turbo build here
            • Jun 2010
            • 2796
            Same ratios... only difference is the rear case.
            • 6A LDY
              • Jul 2014
              • 318
              yeah should be possible, would also be a good time to run through the entire driveline and replace and check over everything
              1988 325iX - sold but not forgotten
              1984 MTech1 323i
              • Bimmer_man
                • Jan 2013
                • 1478
                Yeah I'll be planning on that. Cause so far the fluids don't tell a good story. When I get home I'll post a pic of the fluid that came out. To sum it up it looked like a engine oil change.
