How light is the steering in your IX
  • scarecrow
    • Apr 2013
    • 45
    Comparing my 91 318is to my 91 ix there is a huge difference in steering wheel
    feel. Given the ix is 400 pounds heavier and has front axles i was thinking maybe my steering componets may be worn. The steering also wants to return to the center quicker than normal. What causes that usually, maybe an alignment problem?
  • CrazyPrime
    • Jun 2014
    • 286
    You mean how much effort it is to turn you're wheel? My IX's steering is damn stiff PO had a brand new steering rack installed before I purchased the vehicle so I account my stiff steering to that. And when I say stiff I just mean it is tight.
      • 34844
      RWD steering is a lot lighter than the ix
      • dubdub
        • Oct 2007
        • 295
        There is also a big difference as a function of the tire patch size... get more contact and the amount of effort is increased. I always notice it when I go from summer to snow tires.
        Lots of variables can come into play, so it is tough to gauge what is "normal" but the "wants to return to center quicker" makes me think something is wrong.
        • AndrewBird
          The Mad Scientist
          • 11898
          Caster plays a big part in steering feel. Does the ix have more or less caster than rwd cars? More generally means harder to turn and returns to center more.
            • 34844
            less
            • EyExR
              • Jan 2011
              • 959
              ...could be an alignment issue. Too much toe...? What CABs are on there? Are you seeing uneven wear on your tires?
              The iX may feel heavier in the steering than a RWD but it still pretty darn light when everything is working correctly. Feels like a feather after I've been driving my E34 touring around prior. So it's all relative.
              If it seems unnecessarily hard to turn, I would swap in a known working power steering pump and see if that cures the problem.. But first, check to make sure the belt tension on the PS is correct and the pulley is not misaligned.
              My 325iX DIY Threads:
              Front Wheel Bearing Replacement
              325iX Rear Subframe Bushings and MUCH more w/pics!
              325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
              • AndrewBird
                The Mad Scientist
                • 11898
                Horrible worn out upper strut mount bearings could be binding and creating some friction.
                • dinan3
                  • 52
                  As others mentioned the iX has considerably less caster built in than the RWD. Ie our strut towers are more upright (over the wheel instead of behind it on RWD). I read some pretty good articles on offset CAB to help a little with caster.
                  • dinan3
                    • 52
                    • audiquattrot
                      • May 2008
                      • 3836
                      get an alignment. my steering was WAY loose when my caster was off. Had it aligned, and now the steering is tighter than my E46 M3.
                      www.instagram.com/snwmble
                      #snwmble
                      Current:
                      '05 BMW M3 - Silver Grey/Imola Red
                      '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
                      '15 Mini Countryman - Blazing Red/Carbon Black
                      Past:
                      '01 Audi Allroad - Light Silver/Platinum Saber Black
                      '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
                      '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
                      '90 BMW 325i - Schwarz/Tan sport *Sold*
                      '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
                      • The Dark Side of Will
                        • Jun 2010
                        • 2796
                        Camber plates? Caster's not adjustable stock...
                        • audiquattrot
                          • May 2008
                          • 3836
                          I meant to say toe lol. Reading the threads above threw me off on my typing!
                          #snwmble
                          Current:
                          Past:
                          • packratbimmer
                            • Dec 2009
                            • 1335
                            Make sure your steering coupling is not locking up - I have had them seize and steering is super tight. Shoot it with a good quality lube and work it back and forth while the front is up if you find that it is tight.
                            • 2002tiiguy
                              • Jul 2013
                              • 467
                              if it is really bad, jack up the car and see how easy it is, also listen for clunking, the spring perch in my car had collapsed and it was rubbing on the bottom of the strut mount instead of turning on the bearing
