New IX jack test failed
  • nrubenstein
    • 3148
    Originally posted by barbierij
    What? A worn VC will give you ZERO power to the front wheels. I did a one-wheel peel up my driveway a couple winters ago and that's how I knew both the xfer case and rear diff had bad VCs.
    No. A worn VC will send all power to the axle with no traction. There's a subtle, but important difference.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
      • 34839
      no. the front and rear are mechanically connected through the planetary gear set. the VC controls slip, torque isn't directly transferred through it.
      it doesn't send all power to the rear either! the only reason that happens on a slippery surface is the torque output is already biased towards the rear (via the planetary gear). On a surface with equal traction to all 4 wheels, all wheels get torque regardless of if the VC is working or not. In fact, you could remove the VC entirely and it would still drive all 4 wheels - but it would be an open differential.
      • flyboyx
        • 8371
        if you lifted a front wheel, you can be certain your transfer case vc is good but you will have no way of knowing if the rear diff is good.
        Gigitty Gigitty!!!!
        • e30s50dan
          • Nov 2008
          • 2076
          While both TC were on the ground side by side,I slid in the front drive shaft in the old one,and held the rear drive shaft output,ZERO resistance.... the one I got from a fellow r3v'er,has a lot of resistance (VC good)
          In fact,the old one was so bad,I can stick my fingers in front DS spline,and turn it and feel no resistance
          NASA
          BMWCCA member
          PCA member 25yrs
          1991 318IS slick top
          1997 M3 sedan
          2001 325CI DD
          “whoever turns the wheel the least, wins"
