New IX jack test failed
  • e30s50dan
    • Nov 2008
    • 2076
    just bought a 91 IX with 297k miles on from a BMW tech. Has his own shop for 20years..I brought it home and tried the jack test and the front tires didn't pull me. He said he has never heard of this and not to believe everything I read or see on youtube.
    I also jacked up the front and the rear wouldn't push me.i jack the entire car up with jack stands and all wheels turn,but fronts turn faster
    Also when I had the rear jacked up I turned the drivers side by hand and the passenger wheel didn't do anything
    TC was about dry,so I filled up with ATF ,drove it around,got it good and warm,tried jack test again...FAILED!!
    Any thoughts.?? Guess I need a new TC or at least a VC ........Looks like I just got the shaft..can't even trust a BMW mechanic
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
  • packratbimmer
    • Dec 2009
    • 1335
    The car should pull itself with just the front wheels on the ground. Another quick check is to simply jack ONE front wheel up - if it spins freely with no resistance, the VC needs to be double checked with a jack test.
    • audiquattrot
      • May 2008
      • 3836
      Sounds like a fail to me. Sorry to hear man. I go into every Ix purchase expecting the tc to be bad
      www.instagram.com/snwmble
      #snwmble
      Current:
      '05 BMW M3 - Silver Grey/Imola Red
      '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
      '15 Mini Countryman - Blazing Red/Carbon Black
      Past:
      '01 Audi Allroad - Light Silver/Platinum Saber Black
      '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
      '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
      '90 BMW 325i - Schwarz/Tan sport *Sold*
      '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
      • e30s50dan
        • Nov 2008
        • 2076
        Anyone know the part number for the VC?? car is in really nice condition with a complete respray.
        NASA
        BMWCCA member
        PCA member 25yrs
        1997 M3 sedan
        2001 325CI DD
        • R1dd1ck913
          • Jul 2014
          • 382
          Is.it a auto.ix or stick. I have a tc laying around
          Current
          99 328i (Sold)
          91 318is M50B25TU
          89 325ix (Parted out)
          87 325is (Parted out)
          95 525i (Parted Motor for 91 318is)
          • e30s50dan
            • Nov 2008
            • 2076
            It's a manual
            NASA
            BMWCCA member
            PCA member 25yrs
            1997 M3 sedan
            2001 325CI DD
              • 34844
              • e30s50dan
                • Nov 2008
                • 2076
                I've been searching. Looks like TC priced between $1600-$2000
                Looking for just theVC
                NASA
                BMWCCA member
                PCA member 25yrs
                1997 M3 sedan
                2001 325CI DD
                • packratbimmer
                  • Dec 2009
                  • 1335
                  Here is one example:
                  • jroybower
                    • May 2015
                    • 3
                    A worn VC is not the end of the world. It is still four-wheel drive, just not as capable as it could be. The best I've heard it described is that now the transfer case acts like an open-differential instead of as a limited-slip as originally intended which is consistent with what you describe. The VC can be had for $580 and probably a long wait for it to come over on a boat. Plus labor to install. Good luck.
                    • e30s50dan
                      • Nov 2008
                      • 2076
                      I have another TC. Just waiting on parts. Thanks
                      NASA
                      BMWCCA member
                      PCA member 25yrs
                      1997 M3 sedan
                      2001 325CI DD
                      • Kershaw
                        • 11822
                        make sure you replace the shifter bushings while the TC is out. You can't access it without dropping the TC.
                        AWD > RWD
                        • audiquattrot
                          • May 2008
                          • 3836
                          this was my biggest mistake. Shifter slop all over the place, and had the chance to change it all during the 5-spd swap.
                          #snwmble
                          Current:
                          Past:
                          • E30Jigzaw
                            • 1197
                            Off topic question .. Any of you ix guys happen to have an extra drivers side skirt ?
                            Buy e30 cup holders
                            http://www.r3vlimited.com/board/show...41#post4159541
                            Buy BMW Motosports handles
                            http://www.r3vlimited.com/board/showthread.php?t=302846
                            Buy BMW MOTORSPORT valve covers http://www.r3vlimited.com/board/showthread.php?t=330146
                            • barbierij
                              • Sep 2012
                              • 1294
                              Originally posted by jroybower
                              A worn VC is not the end of the world. It is still four-wheel drive, just not as capable as it could be. The best I've heard it described is that now the transfer case acts like an open-differential instead of as a limited-slip as originally intended which is consistent with what you describe. Good luck.
                              What? A worn VC will give you ZERO power to the front wheels. I did a one-wheel peel up my driveway a couple winters ago and that's how I knew both the xfer case and rear diff had bad VCs.
                              FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
                              Saab/GM tech2 programming
                              My for sale thread
                              1990 325iX for sale or part out
                              Did you buy something from me? Please leave feedback!
                              Originally posted by K20RI_211
                              And I have to ask if you make a hobby out of thread-bombing with retarded questions?
