Wheel/Tire Recommendations 325iX
  • 1988BMW325iX
    • Jun 2015
    • 5
    Is there any reason why I should not size up to 16 inch wheels and run 205 50 r16's vs the stock recommended tire size of 205 55 r15. Also can you safely use an even wider tire like a 225 50 r16 or will that rub?
    Thanks for your help!
  • audiquattrot
    • May 2008
    • 3836
    What is he offset on the wheels?
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • 1988BMW325iX
      • Jun 2015
      • 5
      Most of the wheels that I like have a 37mm or 38 mm offset.
      • mtnbimmer
        • May 2012
        • 73
        Depends on what you are trying to do. I run the 205/50 setup in the summer for better grip. Shorter sidewall means less "roll" when cornering hard. In the winter, I go the opposite direction, 195/65 for a narrower contact patch for better grip in snowy conditions. Taller sidewall helps take the hits instead of the rim.
        • bankrupt
          • Aug 2015
          • 61
          i also need to know. im considering 16x8 et25. will they fit? what size summer tire yall recomend? i use oem bbs for the winter with 192/60 allseasons.
          • 6A LDY
            • Jul 2014
            • 318
            that'll be pretty tight and might rub on the fender, more so if you're lowered at all or have fat friends
            1988 325iX - sold but not forgotten
            1984 MTech1 323i
              • 34839
              ET25 is realistically too low for a 16x8.
