Couple of questions
  • Bimmer_man
    • Jan 2013
    • 1477
    Couple of questions
    Can you take the VC apart and rebuild that or is it a welded unit er something?
    If you can rebuild it could anyone point me in the direction to get what id need or read up on how to do it?
    Second question is in regards to a 24v swap in an iX. Did a quick google search to see if anyone has done a M54 Swap into an iX and if so could i retain my Brake Booster?
    Im curious on the swap because I have a spare block and M54B30 crank i was thinking on doing the 3.0 stroker. However the M54 is a much smoother engine and to be honest it gets better mileage. Also i can get a bit more power out of it for less.
    please let me know.
    Float like a cadillac sting like a Bimmer!:)
    • 34839
    You can rebuild it but you need the proper fluid, with the right air ratio, you need to cut it open and ideally you need a submerged arc welder to seal it back up.
    There's a rubber seal thats cheap but you cave to open up the case to replace it which requires cutting/welding..
    • Bimmer_man
      • Jan 2013
      • 1477
      okay i know of a few places to do that kind of welding. Any data on the fluid and air mixture or where i can read up on it?
      • ghatid
        • Sep 2013
        • 151
        Here ya go.
        Keep us updated on how it goes/how much you ended up spending:D.
        • stonea
          • 2892
          Read that thread for your 24v questions, and I suggest reading all 50 pages and 743 posts, theres A LOT of good information in there (except for my stupid questions, lol). Almost every question can be answered there expect for how to actually do it. You can fraken pan it if you want, but you gotta get ride of the brake booster. I would just do the 3.0 stroker on the old M20.
          My Garage
          Feedback
          Instagram: Stone.Hopkins
