Strut housing question
  • 6A LDY
    • Jul 2014
    • 318
    Quick question about the strut housings. one of my housing tubes has rusted out threads and I need to replace it. I was going to get a non iX strut housing and just cut the tube off of that and replace mine with that section. is there any reason this wouldnt work?
    ( The rest of the housing is in good shape and I'd rather keep it than try to find a good one)
    Thanks
    1988 325iX - sold but not forgotten
    1984 MTech1 323i
  • Nisse Järnet
    • Aug 2013
    • 1221
    Its the same threads so it should be ok?
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
    • JIM1inWisconsin
      • Dec 2014
      • 116
      housings
      Had major problems a few years ago replacing struts and this was an option I considered. Welder was ok with the job but my mechanic didn't want to deal with the Frankenhousing so I bought a used one. I was always curious as to if welding tips on would work. I believed then and do now that it will. Hopefully you will give it try and let us know how it works for you and perhaps include a time, material and cost summary.
        • 34844
        the tubes are different thicknesses. the ix strut housing is a bit beefier. I believe the E36 housings are the same thickness and would make a better donor.
        yes welding it will work. often when housings are sectioned for a coilover conversion, that's exactly what they do. My current housings were from my parts car, and were horribly rusted - the old tubes were cut off and new ones welded on with good thread. he's doing the same thing, except for making them the same length.
        • Northern
          I like cupcakes & sh!tboxes
          • 5262
          I guess you could buy an M48x1.5 tap and tap new thread if you're going shorter and can't reuse the threaded portion because of rust.
          Originally posted by priapism
          Originally posted by shameson
            • 34844
            you could but unless you're going to use it more than once, the tap is so expensive you're better off having it welded.
            • The Dark Side of Will
              • Jun 2010
              • 2796
              Speaking of M48x1.5...
              Originally posted by Teutonic
              Here's two more pictures illustrating why some things are better left to the pros- The oil pressure springs/cup/piston/threaded sender housing cover was test assembled into the girdle. When Greg went to take it back out, he encountered a lot of resistance. Instead of spinning the cover out (like I would have), he worked it back and forth for a while, heated the hell out of the girdle with oxyacetylene, all to no avail. So he lashed the girdle to his mill and machined the cover into about a million filings, making it ~0.003" proud of the girdle surface. Then he cut four reliefs into the remaining threaded portion of the cover, and then knocked out the remaining ring by denting it inwards. Turns out that somehow, the lead thread on the girdle had FUBAR'ed the cover, and would have messed up all the remaining threads had it been turned out. Good save on his part.....
              So- how to chase the threads in a nearly 2" hole? If you're Greg, you bust out your M48 x 1.5 bottoming tap. (fer chrissakes!) My guess is he didn't find it at Sears.......
              From: http://www.corner-carvers.com/forums...5&postcount=23
              The thread details the build of a 6.5 liter Porsche 928 stroker that ends up making 400 RWHP through production exhaust manifolds (passes CA Smog!), 450 through long tubes and 500 with a custom (carbon fiber!) intake manifold... Very pornerific with lots of expensive hardware shown (like the re-Nikasil'd block above)
              • AndrewBird
                The Mad Scientist
                • 11898
                That tap is not cheap!
                http://www.mscdirect.com/product/details/36364651
                Die isn't cheap either:
                http://www.mscdirect.com/product/details/79771960
                  • Jun 2010
                  • 2796
                  Originally posted by AndrewBird
                  Here's a cheaper tap:
                  http://www.mscdirect.com/product/det...37102?fromRR=Y
                  It's not as high a quality as the one you found, but for $300 less...
                  • 6A LDY
                    • Jul 2014
                    • 318
                    Just to follow up on this, I ended up buying a strut housing from a rwd e30, it was the same diameter internally, maybe a little thinner overall. I cut off 1.5" from the top to have the threads and a bit left over. I cut a tiny bit more than 1.5" off of my ix housing and prepped it to weld. Then I used the old blown out strut insert I had to center the thread piece and tacked it on. It worked pretty well and I only had to grind the inside down a tiny bit to smooth it out.
                    I wouldn't recommend going any further than 2" from the top to someone else because it gets hard to get the grinder down inside to smooth out anything that blew through. Also try to stand the strut vertically, especially if you dont have a junk strut because it gets difficult to align it. The strut I used was pretty dry and empty but I wouldnt recommend trying to weld against a fresh one for fear of heating it up too much or damaging it. Also if for some reason you weld the strut to the housing it would be a pita to remove it
                    All in all it was pretty painless and a lot cheaper than buying an ix strut
                    1984 MTech1 323i
                    • chuckdizzle
                      • May 2011
                      • 211
                      ;D awesome. I think I need another pair soon, mine are starting to rust away.
                      • JIM1inWisconsin
                        • Dec 2014
                        • 116
                        strut housing
                        I know used E30 strut housing can be had for cheap. Can I ask how much time you spent doing the cutting and welding? Nice to finally know this method works.
                        • 6A LDY
                          • Jul 2014
                          • 318
                          I spent a few hours total on it probably. In order to remove the threaded section from the non-ix housing, using a cutoff wheel, I had to cut off the spring perch plate first, then the threaded section. I used a wide piece of tape roughly centered at the 1.5" mark then measured it from the top at multiple spots around the tube and marked it on the tape and connected the dots.
                          The actual cutting wouldnt take too long, maybe an hour total, but measuring both housings properly and then taking your time to ensure a straight cut adds a little time. Grinding off the paint and cleaning the pieces takes maybe 15 minutes. Getting everything set up to weld took me about a half hour because I wanted it to be as straight as possible. I used the collar nut with the old strut I had to hold the new piece on at the height I wanted and tightened nut to put a little gap for the weld to fill.
                          The welding takes maybe 10 minutes, then clean it up a bit and primer it and paint it and let it dry. I also had to clean up the inside of the housing a bit with a die grinder but that only took a little time.
                          All in all I'd say it would take maybe 4-6 hours? I did it over the span of two days but it could be done in a day and definitely over a weekend. The longest part is the prep work as always
                          1984 MTech1 323i
                          • 6A LDY
                            • Jul 2014
                            • 318
                            1984 MTech1 323i
                            • JIM1inWisconsin
                              • Dec 2014
                              • 116
                              Again, great effort and write up. IX owners have been battling rusted strut housings for years. Nice to know there's an alternative that can be had for less than $500. Even less if you are as skilled as 6A LDY.
