Poly cabs on 325ix?
  • Julien
    • 7471
    Poly cabs on 325ix?
    Any reason to not go with poly cabs on a 325ix as long as they are centered?
    Thanks!
    Build Threads:
    • 34844
    Offset work fine too, as long as you are lowered.
    Personally, too much NVH for me..
    • flyboyx
      • 8371
      i suggest stock m3 bushings. that is what i always use. if you run 17" tires they will rub a little on the front of the inner fenders when you make tight turns.
      Gigitty Gigitty!!!!
        • 34844
        what do you mean 17" tires? If you run the proper + size, the diameter doesn't change with wheel size.. but most aftermarket wheels are likely to have a lower offset.
        I don't get much rubbing with the R888s, but when I have 235/50R15s, it rubbed quite a bit at full lock.
