rwd coilovers
  • Julien
    • 7471
    rwd coilovers
    Do you guys think it would be possible to run this style (bc racing/etc: weld on) coilover on a 325ix?
    http://www.ebay.com/itm/COILOVERS-SU...xVJhnZ&vxp=mtr
    I know these things go way low on a regular e30 which makes me think they might work for us for moderate lowering with decent suspension travel. I'm not sure about the upper bushings though. Does the 325ix use a different bolt pattern than a rwd e30 for the strut bearing (i know the design is different)? Perhaps using a ground control camber plate would fix that?
    Just thinking out loud
    Thanks
    Build Threads:
  • Kershaw
    • 11822
    You have to use the ix specific strut mounts like the GC you linked.
    AWD > RWD
      • 34844
      No. They're crap anyway.
      The gc kit will work though.
      • Julien
        • 7471
        Care to elaborate? I had them on my 5 lug car and really liked them
        Build Threads:
        • flyboyx
          • 8371
          i think its relative. they are cheap. generally, the build quality isn't there compared to ground control or h&r. you will need camber plates to fit an ix. obviously as you know the front struts are shorter. otherwise they will fit the car.
          Gigitty Gigitty!!!!
            • 34844
            cheap dampers, mainly.
            • The Dark Side of Will
              • Jun 2010
              • 2796
              Ditto. Dampers and tires are *mostly* black boxes into which you just have to throw money to get results.
