ix shifter arm interchangeable?
  • packratbimmer
    • Dec 2009
    • 1335
    Both probably plant the shifter in the same spot. I suspect that the iX version just has the bend in it and the "cup" reinforcement for clearance issues only. One could likely use an iX arm in a RWD, but not the opposite.
      • 34839
      yeah I think it raises the shifter up to clear the transfercase. it's really tight in there even with that adjustment.
      maybe you could use the RWD arm with one of those IE parts that raises the shifter up, but personally I'd rather run that part with the ix arm so I could run a shifter with a shorter throw.
