1991 Ix Manual Transmission Swap Pictures
  • 2santiago
    • Aug 2015
    • 84
    Still have to clean the ends
    Nothing surprising. Any particular brand for these?
    • 2santiago
      • Aug 2015
      • 84
      Was very glad to see the trans fluid almost bright red.
      • 2santiago
        • Aug 2015
        • 84
        Look what I was greeted to when I walking in the door from work...
        Now I can keep going!!!
        • The Dark Side of Will
          • Jun 2010
          • 2796
          WTF is going going on back in your planetary set? Looks like the VC hub has been welded?
          • 2santiago
            • Aug 2015
            • 84
            Glad you asked that. I almost forgot to ask you guys if that is normal. Is it? I assuming no based on your comment. I had other things going on Friday and Saturday but I am about to install the shift seals in a few.
            • 2santiago
              • Aug 2015
              • 84
              Replaced #23 and will replace the others as soon as I order the mount. I want to install the mount before putting the other seals.
              • 2santiago
                • Aug 2015
                • 84
                If I read correct there is only a rubber mount(non solid) for the transfer case cross member. Any ways to upgrade this or should I order the oem one?
                  • 34839
                  There is nothing but the OEM option. Unless you're pushing several hundred hp, i don't see a reason to worry about it.
                  • 2santiago
                    • Aug 2015
                    • 84
                    Sounds good! [emoji106][emoji51] I will order one as soon as I arrive home.
                    • 2santiago
                      • Aug 2015
                      • 84
                      Just came in today, OEM transmission/transfer case mount. I'll have to wait until next week. Birthday weekend!!!! [emoji16][emoji57]
                      • Nisse Järnet
                        • Aug 2013
                        • 1221
                        Nice :) Be sure to press it in in the right position.
                        E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                        E30 M50 6 spd 764whp @ 24psi.
                        E30 M20 6 spd 675whp.
                        • ThatM20Guy
                          • Aug 2014
                          • 601
                          Any updates? I'm thinking of doing the same thing on my ix.
                          89' 325ix Diamantschwarz/Black rattle can...
                          Insta: r_moose_w
                          Originally posted by flyboyx
                          I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
                          • 2santiago
                            • Aug 2015
                            • 84
                            A year later and finally had a chance to remove the automatic transmission.
                            • 2santiago
                              • Aug 2015
                              • 84
